Sanding Sponges?
Forum topic by jasoncarpentry posted 11-22-2013 06:40 PM 1427 views 1 time favorited 14 replies Add to Favorites Watch
View jasoncarpentry's profile
jasoncarpentry
142 posts in 2684 days
11-22-2013 06:40 PM
Topic tags/keywords: sandpaper sanding sponges
I make lots of pieces w/ either quarter-round or half-round edges. Since there are usually some burn marks, I end up sanding these contours. I’m using mostly maple, so it’s tough going. I’ve been using scraps of sandpaper, but it’s hard to keep track of these, plus it’s fatiguing on my old hands.
In the past, I’ve used sanding sponges, but that’s not something you can buy from Ace, HD, etc. So what brand of sanding sponges do you use? I found one source which looks pretty good:
http://www.nortonconsumer.com/uploadedFiles/SGnortonconsumer/Documents/AbrasiveSpongeSpecifications-DIY340.pdf
A good idea for “stocking stuffers”!
-- Jim in Tennessee
14 replies so far
View Tedstor's profile
Tedstor
1643 posts in 2662 days
#1 posted 11-22-2013 06:42 PM
I’m pretty sure I bought my sponges at Lowes. 3M I think.
View CharlesNeil's profile
CharlesNeil
2412 posts in 3900 days
#2 posted 11-22-2013 06:44 PM
View bondogaposis's profile
bondogaposis
4771 posts in 2380 days
#3 posted 11-22-2013 07:36 PM
I make my own and much prefer them to the store bought ones. I get some 6mm craft foam from the craft store and glue it to a scrap of wood that measures 5 1/2” x 2 3/4”. Then I just wrap 1/4 sheet of sandpaper around it and away I go. Here one I have had around for as long as I can remember.
-- Bondo Gaposis
jasoncarpentry
#4 posted 11-22-2013 08:03 PM
Thanks to all for your suggestions. CharlesNeil: Looks like the “Rhinosoft” pads don’t offer any grits below 180. Am I missing something?
-- Jim in Tennessee
View AlanBienlein's profile
AlanBienlein
159 posts in 2704 days
#5 posted 11-22-2013 08:07 PM
I use the purple 3M ones from Sherwin Williams.
Mainly the fine and X-fine for finishing as they never seem to wear out and a medium for sanding contours or breaking edges on raw wood.
View 12strings's profile
12strings
434 posts in 2414 days
#6 posted 11-22-2013 08:25 PM
I got mine at Lowe’s…3m. I use the coarse ones all the time on the shop…fine ones when i Patch drywall…
-- I'm strictly hand-tool only...unless the power tool is faster and easier!
jasoncarpentry
#7 posted 11-22-2013 09:26 PM
Unfortunately, we don’t have a Lowe’s any closer than Knoxville, where the traffic is a nightmare!
CharlesNeil: I found the coarser grits elsewhere on the site you recommended. Thanks!
-- Jim in Tennessee
View SuperCubber's profile
SuperCubber
1028 posts in 2314 days
#8 posted 11-23-2013 12:24 AM
Why not just stick some sand paper to a matching piece of cove molding or PVC?
-- Joe | Spartanburg, SC | "To give anything less than your best is to sacrafice the gift." - Steve Prefontaine
View quartrsawn's profile
quartrsawn
146 posts in 3242 days
#9 posted 11-23-2013 01:13 AM
Try cshardware.com
-- Nat - West Sayville,L.I., NY
View Dallas's profile
Dallas
3599 posts in 2516 days
#10 posted 11-23-2013 01:21 AM
Slow the grit mobile!
”Since there are usually some burn marks”,
Leads me to believe you are moving too slow through the cut, the bit is dull or the router is spinning too fast.
change one or another, (probably speed of router), and see what happens.
View Rick's profile
Rick
9753 posts in 3062 days
#11 posted 11-23-2013 01:59 AM
I buy mine at Home Depot. 3M seems to be one of the best choices.
Norton Paper Quality of any kind seems to have gone downhill in the last year or so. I use to buy there Best Grade as I did the last time. For The Pits!!
Good Suggestion from “Dallas”.
-- LIFE is what happens when you're planning on doing Other Things!
View oldnovice's profile
oldnovice
6904 posts in 3397 days
#12 posted 11-23-2013 05:29 AM
jasoncarpentry, I agree with Dallas in that you are probably moving too slow!
But, when those burn marks do rear their ugly appearance, I use the sanding sponges for round overs as I feel that the “give” of the sponges do a very good job on the corners … better than anything else I have tried. I buy mine at OSH, Orchard Hardware Supply, which has about 90% of my wood working supplies except for lumber. 3M, and sometimes Norton, are the brands I use. I have never bought any online or even price checked to see if I can get a better deal!
I was them out after using them which I don’t know how it affects the life of the sponge.
jasoncarpentry
#13 posted 11-23-2013 02:54 PM
rommy-
I think you posted this in the wrong place.
-- Jim in Tennessee
View PaulDoug's profile
PaulDoug
1551 posts in 1733 days
#14 posted 11-23-2013 03:09 PM
I buy my sanding supplies from here. They have from 60 grid on up.
http://www.woodworkingshop.com/product/fa02406/
