Crosscutting Dadoes
« back to Joinery forum
Forum topic by wookie posted 11-22-2013 06:25 PM 1146 views 0 times favorited 15 replies Add to Favorites Watch
View wookie's profile
wookie
154 posts in 2955 days
11-22-2013 06:25 PM
Topic tags/keywords: crosscuting dadoes table saw question
Hi Everyone,
I have to crosscut some dadoes in some plywood boards that are 15 7/8” wide by 8’ long on the table saw. I would like to use the fence and push them through with the mitre that also has s fence on it . I am going to square the mitre to the fence. Two guys will be guiding the pieces through. Will this work for accuracy and safety wise? Don’t want to get anything in a bind. Sound good or not?
Thanks,
Jack
-- Wookie=Wood Rookie
15 replies so far
9762 posts in 3519 days
#1 posted 11-22-2013 06:27 PM
You can do it that way but I prefer to use the fence as a stop
by attaching a board to it that stops shy of the front of the
blade.
View sdmref's profile
sdmref
15 posts in 3078 days
#2 posted 11-22-2013 06:37 PM
Loren is on the money for the proper way to do it on the table saw, but DO NOT use the fence and miter guage together w/o a block to bump it out from the fence, you are asking for kickback if you don’t use one. You can also use a router and clamp a straight edge across the board which would be much safer.
View bigblockyeti's profile
bigblockyeti
4881 posts in 1592 days
#3 posted 11-22-2013 06:38 PM
8’ is pretty wide to be going across the tablesaw, would be safer to do that on a radial arm saw. If it must be done on the tablesaw, screw an auxiliary fence to the face of the miter gauge, the wider the better. If you have a miter gauge with screws to adjust how tight it fits in the miter slot, make sure it’s as tight as can be and still slide safely. Any minor slop in the fit will be greatly amplified at the end of the board. Might not be a bad idea to clamp the board the auxiliary fence on the miter gauge to further prevent movement.
View jmartel's profile
jmartel
7626 posts in 2021 days
#4 posted 11-22-2013 06:40 PM
Straight edge and a router is going to be better.
116804 posts in 3448 days
#5 posted 11-22-2013 06:44 PM
I second the router and straight edge ,much easier.
View pintodeluxe's profile
pintodeluxe
5544 posts in 2684 days
#6 posted 11-22-2013 06:54 PM
For bookshelf dados, and projects where the workpiece is long, I use an Emmerson clamping straightedge and a plunge router. I also use a shop made dado guide for custom width dados.
View TheDane's profile
TheDane
5348 posts in 3534 days
#7 posted 11-22-2013 06:59 PM
I would not consider using my tablesaw for this cut … what happens if one of the two guys supporting the board gets a little ahead or behind? BANG … kickback.
If you don’t have a RAS, then a router and shop-made jig will get the job done quickly and safely.
View RockyTopScott's profile
RockyTopScott
1186 posts in 3350 days
#8 posted 11-22-2013 07:07 PM
If there is a mating side (2 pieces) it might have been better to cut the dados then rip the plywood to 15 7/8.
-- “When you want to help people, you tell them the truth. When you want to help yourself, you tell them what they want to hear.” ― Thomas Sowell
View bondogaposis's profile
bondogaposis
4525 posts in 2222 days
#9 posted 11-22-2013 07:22 PM
Don’t get me wrong I cut a lot of dadoes on the table saw, but in my shop I would never attempt that cut. Eight foot is too long to handle. I would much prefer to do this w/ router. RockyTopScott has the right idea too, route the dadoes then cut in half for two mating sides.
-- Bondo Gaposis
View MT_Stringer's profile
MT_Stringer
3133 posts in 3102 days
#10 posted 11-22-2013 08:37 PM
Make an exact width dado jig like this one and get on down the road…safely. :-)
Hope this helps.
Mike
View DangerDoug's profile
DangerDoug
72 posts in 1518 days
#11 posted 11-22-2013 08:45 PM
Radial arm saw – about the only thing they are good for.
OR router, just need to correct order bit.
View ajosephg's profile
ajosephg
1880 posts in 3432 days
#12 posted 11-23-2013 12:15 AM
No way can an 8 foot board be cut accurately as described. Router with jig is the way to go.
-- Joe
View waho6o9's profile
waho6o9
8066 posts in 2448 days
#13 posted 11-23-2013 12:23 AM
Router with jig and make your cuts on the 4×8 sheet
and then rip to size, done.
View sixstring's profile
sixstring
296 posts in 2114 days
#14 posted 11-23-2013 12:41 AM
if you have an extension wing that’s wide enough to support most of the piece, build a crosscut sled deep enough to accept it. i just did this recently for a 6’ long piece of 3/4 ply. in this way, i was able to safely crosscut the piece without any help. i suppose going back and forth to cut a dado makes this even more dangerous.
but yes, the router and straight edge has to be considerably safer so why take chances.
-- JC Garcia, Concord, CA : "It's easier to ask forgiveness than permission..."
wookie
#15 posted 11-23-2013 06:34 AM
Thanks, guys. This why I put up this post. I was out voted on cutting the dados first then ripping to width.
