driving screws for metal drawer slides straight into melamine covered chiphoard
Forum topic by Vjeko posted 11-22-2013 09:43 AM 1405 views 0 times favorited 4 replies Add to Favorites Watch
View Vjeko's profile
Vjeko
135 posts in 3319 days
11-22-2013 09:43 AM
Topic tags/keywords: question
long title / simple question for the experienced – just in case there is a better way to do it
since quite a bit of work is ahead of me in the house and maybe I can do it better/learn
something.
When mounting metal drawer slides/glides eg Blum – I usually just locate the drawer part, mark and
center punch lightly into the melamine to make it easier to screw the small screws.
The problem is that sometimes the screws don’t go in perfectly straight and
the head is not seated perfectly – do I just need more practice or is there something
I can do to improve the result ?
-- Vjeko Balas - Croatia
View kaerlighedsbamsen's profile
kaerlighedsbamsen
1239 posts in 1618 days
#1 posted 11-22-2013 10:39 AM
Have you seen these?: http://www.dilegnosupply.com/Drilling-Boring/self_centering_drill_bits.htm
-- "Do or Do not. There is no try." - Yoda
View SuperCubber's profile
SuperCubber
1015 posts in 2189 days
#2 posted 11-22-2013 12:09 PM
+1 to the above post. At the very least, predrill the holes, if you aren’t already doing so.
-- Joe | Spartanburg, SC | "To give anything less than your best is to sacrafice the gift." - Steve Prefontaine
View Gene Howe's profile
Gene Howe
10115 posts in 3333 days
#3 posted 11-22-2013 01:31 PM
+1 and, I’d dab a bit of CA on the screws. Chip board is not the best at holding screws.
Vjeko
#4 posted 11-22-2013 02:13 PM
OK, thanks, so even though these screws are very small you suggest predrilling with
a centering drill bit – will try it
