euro hinge problem
Forum topic by justbob posted 11-21-2013 01:19 AM 778 views 0 times favorited 4 replies Add to Favorites Watch
View justbob's profile
justbob
16 posts in 2060 days
11-21-2013 01:19 AM
I am building a cabinet with inset doors and using soft closing European hinges. The problem I am having is the doors close past the front of the cabinet by 2 inches or so. Is there an adjustment to change how far the door travels.If not how do I fix it.
View GOOD LUCK TO ALL's profile
GOOD LUCK TO ALL
418 posts in 1690 days
#1 posted 11-21-2013 01:21 AM
Nope, you need to make some kind of a door stop.
I’ve cut small pcs (like 3/8×3/8) and run them all the way across the cabinet, set in behind the doors including space for the door bumper, if you’re using one. You can stain it the same color as the cabinets.
I have also just used small Alum. L channel cut to about 2-3 inches wide. (you could paint them black)
View firefighterontheside's profile (online now)
17927 posts in 1819 days
#2 posted 11-21-2013 01:27 AM
I think you’re gonna need a stop of some sort.
404 - Not Found
2544 posts in 2931 days
#3 posted 11-21-2013 01:27 AM
I usually use nail-in shelf supports. Whatever you decide do it top and bottom or the door will twist over time from the tension in the spring hinges.
View pintodeluxe's profile
pintodeluxe
5618 posts in 2775 days
#4 posted 11-21-2013 02:05 AM
I use little metal “L” brackets with self adhesive cork bumpers. The brackets are perhaps 1/2” square, and unobtrusive. You will find them with the drawer hardware in building centers and big box stores.
I get the kind with a slotted hole. That way I can drill once, and make adjustments as necessary.
