Router Extension
Forum topic by Dave Dye posted 11-20-2013 05:23 PM 911 views 0 times favorited 9 replies Add to Favorites Watch
View Dave Dye's profile
Dave Dye
8 posts in 2343 days
11-20-2013 05:23 PM
How do you extend a 3/4” router bit. If you use an extension, it’s bigger than the bearing on the 3/4” bit. Perplexed.
-- Dave Dye
9 replies so far
View PurpLev's profile
PurpLev
8536 posts in 3675 days
#1 posted 11-20-2013 05:28 PM
if you need to “extend” the bit to reach deeper then it’s cutting flutes you would have to get a longer cutter.
most extenders are designed to allow the bit to extend more from the base of the router – not for it to cut deeper than it is designed to.
View bowedcurly's profile
bowedcurly
519 posts in 1755 days
#2 posted 11-20-2013 06:14 PM
how deep are your flutes, flutes should only be 1/2 inch at most the bit should extend at least 3/4 of an inch, don’t understand question I guess me so dumb.
-- Staining killed the wood<<<<<>>>>>Dyeing gave it life
404 - Not Found
2544 posts in 2996 days
#3 posted 11-20-2013 11:44 PM
Use a straight 1/2” worktop cutter with a 2” depth of cut and take out one cut progressively, move the fence 1/4” and take out the rest.
Edit, Since you mention a bearing on the 3/4 bit, use a guide bush with the half inch cutter and make the template to accommodate the guide bush.
What kind of shapes are you cutting and how deep do you need to go? I’ve seen 1 1/2 long bearing guided 3/4 straight cutters on the bay.
Or, if you are shaping curves in thick material, use your top bearing guided cutter with a template, bandsaw out near the line, flip the work piece and use a long bottom bearing guided cutter running the bearing against the shape you already cut on the other side.
Dave Dye
#4 posted 11-21-2013 01:30 PM
I”m sorry, I didn’t explain my self very well. I using a plunge router with a 3/4” dish cutter bit. In order to cut a deeper bowl you normally use a collet extender. However, the extender is bigger than the bearing on the 3/4” bit, therefore, the bearing will not make contact with the pattern or the side of the already routed out bowl. Any ideas will help.
Thanks
Dave
-- Dave Dye
bowedcurly
#5 posted 11-21-2013 03:05 PM
you need to go with the 1 1/4 inch dish cutting bit that will solve your problem I have two whitside bowl bits and have no problems with my extension the 3/4 will not work unless you have it special made or have a special extension made I hope this helps
bowedcurly
#6 posted 11-21-2013 03:08 PM
or you can make somekind of fence or pattern to use but I think the bigger dish cutter will help all you need is the bit everthing else bein a 1/2 in shank good luck have a good day
PurpLev
#7 posted 11-21-2013 03:17 PM
in that case – use a wider bit as mentioned above.
or find another method of making that cavity
Dave Dye
#8 posted 11-21-2013 05:09 PM
Thanks, the wider bit won’t work, I’m cutting a pattern with only a 3/4” indentations. I’ll keep thinking. Maybe an extension for a 1/4” bit will work, it looks smaller.
-- Dave Dye
bowedcurly
#9 posted 11-21-2013 07:08 PM
ching chang ching chang ching chang ching ching chain
