How do you do this?
Forum topic by RussellAP posted 11-20-2013 04:57 PM 1487 views 1 time favorited 20 replies Add to Favorites Watch
View RussellAP's profile
RussellAP
3104 posts in 2401 days
11-20-2013 04:57 PM
I have a design for a table in mind that will take some smaller strips of walnut and or maple. I want to cut precise 1/2 inch strips off of boards 3 foot in length. I’d like the action to be repeatable without remeasuring each cut.
What’s the most efficient way to cut these 1/2” by 3 foot stripes of wood?
Bear in mind that my bs is not good for this sort of resaw, it’s set up for curves.
I would like to use the TS for this.
20 replies so far
16276 posts in 4333 days
#1 posted 11-20-2013 05:02 PM
Sounds to me like a job for a thin rip jig. Here is one from Rockler, but they are fairly easy to make on your own.
RussellAP
#2 posted 11-20-2013 05:19 PM
CharlieM, that’s not exactly what I’m looking for. I’m wondering if I could rip it between the blade and the fence. If it was set up straight and I used a push stick and clamp a small piece of wood to the fence so the 1/2 cut off piece isn’t up against something tall, if that would work.
I don’t usually rip anything less than 1.5 inches between the blade and the fence though.
View PurpLev's profile
PurpLev
8540 posts in 3763 days
#3 posted 11-20-2013 05:26 PM
with featherboards (pushing board against fence for consistent 1/2” width of cut, and one mounted on fence and pushing down) and 3/8” push block, I think you can safely and easily run this on the TS. I find that ~1/2” push blocks are sturdy enough to keep things safe as long as you make them large enough to keep your hands away from blade area.
now… 1/8” slices I would probably NOT do on the TS ;)
View MarkwithaK's profile
MarkwithaK
370 posts in 3293 days
#4 posted 11-20-2013 05:30 PM
I’ve ripped 1/2” maple ply into 1/2” wide strips quite a bit with very good results on the TS just as you have mentioned. I’d say give it a try….you never know what you can accomplish until you try.
-- If at first you don't succeed then maybe skydiving isn't for you.
View Jay Nolet's profile
Jay Nolet
75 posts in 2154 days
#5 posted 11-20-2013 05:48 PM
I use a 2 X 8 about 1’ long with a 1 1/2” X 5” X 1/4 thick piece screwed (up high) to the back end 1/4” lower than the 2 by. The push block pushes both pieces thru the blade. The blade does cut into the block a little the first cut. This is what I used when cutting 1/2” strips for a tumbling block pattern.
-- I think, therefore I think I am.
View Ripthorn's profile
Ripthorn
1458 posts in 3100 days
#6 posted 11-20-2013 05:50 PM
I would use a thin rip jig. But if you choose not to, you can get some 1/2” MDF, cut several strips however wide you want (1.5” would work), stack them on their side butted up against the fence. Move your fence so that your “stack” of strips touches the blade, remove one, run your workpiece through, remove another, etc. until you run out of strips. I personally think a thin rip jig would be much easier, but there is an alternative for you.
117203 posts in 3692 days
#7 posted 11-20-2013 06:00 PM
I was thinking of the same thing Charlie brought except a shop made jig.
http://lumberjocks.com/projects/40215
http://lumberjocks.com/projects/71983
http://lumberjocks.com/projects/66175
There’s a few more on Ljs
View Danpaddles's profile
Danpaddles
573 posts in 2427 days
#8 posted 11-20-2013 06:01 PM
I find repeat-ability pretty good with the Rockler jig, but – I do thinner than that with the fence, often. Feather boards are strongly advised. No problems, use a push stick that reaches out a foot or more.
Something sort of like this-
http://lumberjocks.com/projects/37148
And- no one mentioned- you might think about a zero clearance insert, depending what your present insert looks like. And double check that your blade is truly vertical, and in line with your fence.
-- Dan V. in Indy
View woodsmithshop's profile
woodsmithshop
1327 posts in 3660 days
#9 posted 11-20-2013 06:17 PM
Russell, I too cut a lot of thin strips, and it is aggravating when you waste more with the kerf than what you get for use, so I tried a 1/16” kerf blade, I use a Dewalt 7 1/4” 24 t00th framing blade, and it works pretty good without wasting so much wood, and they are cheap, around 7 or 8 $, that is less than what you would lose using a regular thin kerf blade if you are cutting some exotic wood.
just my .02 cents worth.
-- Smitty!!!
Danpaddles
#10 posted 11-20-2013 06:30 PM
Smitty- how clean is the cut? Saw marks?
-- Dan V. in Indy
View casual1carpenter's profile
casual1carpenter
354 posts in 2590 days
#11 posted 11-20-2013 06:50 PM
Russell, I know you stated that you want to use the table saw and the rip’ed section at or towards the fence. Often when I rip lumber the piece or pieces deform due to the wild locked in stresses.
However this sounds like a perfect track saw type scenario depending I guess on the depth of cut required. There are numerous postings on LJ’s of easy shop built solutions for tracksaw like cutting that could yield accurate the repeatable rips that you are seeking.
View Elizabeth's profile
Elizabeth
817 posts in 3258 days
#12 posted 11-20-2013 06:56 PM
I got a Grr-Ripper set for Christmas last year and it’s designed for this sort of cut (among other very useful functions).
http://microjig.com/products/grr-ripper/
404 - Not Found
2544 posts in 3084 days
#13 posted 11-20-2013 07:07 PM
Just rip them a whisker on the wide side and pass them through the planer to get them all the same width. If your anxious about being too close to the fence for a push stick, rip half length and flip the board.
View moke's profile
moke
1229 posts in 2891 days
#14 posted 11-20-2013 07:07 PM
+1 with Elizabeth Grr-Rippers are awesome…I have a ultra thin rip adapter and regularly rip down to 1/8
Mike
-- Mike
View MT_Stringer's profile
MT_Stringer
3173 posts in 3346 days
#15 posted 11-20-2013 07:16 PM
Russell. I made a jig similar to the Rockler jig using a bearing from a router bit bearing set. I cut 1/4 inch pieces of walnut for cutting boards.
