What glue to stick rubber/vinyl liners into my tool tote?
Forum topic by bobasaurus posted 11-18-2013 08:11 PM 1684 views 0 times favorited 9 replies Add to Favorites Watch
View bobasaurus's profile
bobasaurus
3444 posts in 3180 days
11-18-2013 08:11 PM
I’m building a wooden tool tote and I want to get a rubber (probably actually vinyl or some other plastic substance) tool box liner to cover the ugly plywood bottom. What type of glue should I use for this? Seems like most glues wouldn’t stick the rubbery liner to the finished plywood. Maybe a silicone RTV or some kind of epoxy? This is the type of liner I’m looking at:
Thanks for the help.
-- Allen, Colorado (Instagram @bobasaurus_woodworking)
9 replies so far
View JesseTutt's profile
JesseTutt
854 posts in 2106 days
#1 posted 11-18-2013 08:13 PM
Epoxy would be messy but it should work. You might need to also consider temperature.
—Jesse
View Loren's profile
10381 posts in 3644 days
#2 posted 11-18-2013 08:14 PM
I would use double sided carpet tape. It’s useful in the shop
otherwise too. Lay it down and clamp it or pound it with
a mallet and it can stick pretty good to most flat surfaces.
bobasaurus
#3 posted 11-18-2013 08:19 PM
Loren, about how thick is carpet tape? Will I notice the taped area through the mat? It sounds like a really good solution.
#4 posted 11-18-2013 08:23 PM
Oh it’s quite thin. It might telegraph through thin paper
but that’s about it.
bobasaurus
#5 posted 11-18-2013 08:28 PM
Thanks, I just ordered a roll. I’ll have to check out rubber liners at the local big box. Hopefully this will keep tools from slipping around.
View kaerlighedsbamsen's profile
kaerlighedsbamsen
1246 posts in 1709 days
#6 posted 11-18-2013 10:01 PM
For rubber you should use contact cement. Preferably of the non-watersoluble kind
-- "Do or Do not. There is no try." - Yoda
bobasaurus
#7 posted 11-18-2013 10:10 PM
I’ve never had good luck using contact cement on veneer, but maybe it works well for rubber. I might try that if the tape fails.
View JoeinGa's profile
JoeinGa
7736 posts in 2003 days
#8 posted 11-18-2013 10:24 PM
Contact cement WILL work. Just remember to follow the “destructions”... You GOTTA put it on BOTH surfaces and let it set up for a while. Most folks get too antsy and try to put the 2 surfaces together too soon. THAT’s usually the cause of the failure.
View Carbide's profile
Carbide
210 posts in 2442 days
#9 posted 11-19-2013 08:02 PM
3M spray adhesive. Spray on both surfaces and then join them together. Similar to contact cement.
-- When it feels like a job, it isn't a hobby anymore.
