SYP drying time
Forum topic by 12strings posted 11-17-2013 07:35 PM 1271 views 0 times favorited 9 replies Add to Favorites Watch
View 12strings's profile
12strings
434 posts in 2380 days
11-17-2013 07:35 PM
Topic tags/keywords: syp workbench
I just got some Southern Yellow pine 2×10’s form the home center for a workbench build, I cut it into 5-foot lengths and and stickered it to dry. How much time should I wait until I start building?
It is advertised as “kiln-dried” which in reality means “pretty wet.”
Keep in mind this is drying in my garage, and the bench will stay in my non-heated, non-AC garage.
Thanks for any advice.
-- I'm strictly hand-tool only...unless the power tool is faster and easier!
9 replies so far
View Woodknack's profile
Woodknack
11610 posts in 2376 days
#1 posted 11-17-2013 11:11 PM
I would let it go as long as you can, a few weeks to a month minimum.
View WDHLT15's profile
WDHLT15
1741 posts in 2472 days
#2 posted 11-18-2013 02:40 AM
Put a box fan blowing through the stack and that will speed the drying considerably.
View djwong's profile
djwong
176 posts in 3216 days
#3 posted 11-18-2013 04:38 AM
I had some very wet Douglas Fir 4×6’s from the Borg. The way I determined when to start using them was by weighing them. I weighed each beam and wrote the weight on it. I would then weigh them every week and write the weight down. When the weight no longer changed, I assumed the moisture content had stabilized and I could safely use the wood. In my case, it took 6-9 months.
-- David W. Cupertino, CA
View Loren's profile
10381 posts in 3644 days
#4 posted 11-18-2013 04:50 AM
Months if you want to rip, joint, plane and face glue it. Anything
you can do to increase the heat and air circulation will speed
it up. I read somewhere (here I reckon) about putting black
plastic over it and putting it in the sun with room under the
plastic for a good air circulation. Turns your wood pile into
a solar still.
View Whiskers's profile
Whiskers
389 posts in 2023 days
#5 posted 11-19-2013 08:03 AM
Southern yellow pine is so hard to find it seems, even here in north Alabama. I found some beautiful 1×6x10s though a couple months back and pulled the plumiest pieces out for making drawers. Ive got a nice little stack of it though, never seen 2x stock ever here and I have looked for it. I guess I got lucky though cause I think it looked sufficiently dry to use immediately, although most of it is still waiting on me to start chopping.
View Nomad62's profile
Nomad62
726 posts in 2954 days
#6 posted 11-20-2013 04:26 PM
Since it will be in a garage environment it will move if it wants to at any time; I’d think letting it acclimate to that environment for 2 weeks to a month should be sufficient. If the wood isn’t stressed it will work fine.
12strings
#7 posted 11-21-2013 01:34 AM
Nomad62, that’s the answer I’ve been wanting to hear! Why couldn’t Loren give me that same answer?? :-)
Come one guys, just tell me what I want to hear!!!
Nomad62
#8 posted 11-21-2013 04:21 PM
Lol, okay, now send me my $5!
View Earlextech's profile
Earlextech
1161 posts in 2686 days
#9 posted 11-21-2013 04:50 PM
SYP should have come out of the kiln with 19% moisture content – if you get it down to 10% you should be good to go. Buy a meter, about $40at the big box. There’s a tool for every job.
http://www.homedepot.com/p/General-Tools-Digital-Moisture-Meter-with-LCD-Display-MMD4E/100651808
