Spraying polyurethane varnish
Forum topic by ashahidan posted 11-17-2013 07:26 AM 1040 views 0 times favorited 1 reply Add to Favorites Watch
View ashahidan's profile
ashahidan
64 posts in 3337 days
11-17-2013 07:26 AM
Dear friends,
i am going to spray a table with clear polyurethane varnish. I will be using a compress air sprayer.
I have bought a a liter of ICI polyurethane varnish and there is no instruction to show how much thinner I should add to the varnish before spraying.The instruction only says I should add 20% thinner for the first coat if I were to use a brush. And that is all.
Please let me know how much thinner I should mix with the varnish .
ashahidan
-- asm
1 reply so far
5236 posts in 2732 days
#1 posted 11-17-2013 01:19 PM
That’s not a straight forward answer. It depends on the gun itself, and the size of the opening in the needle set as well as air pressures and several other things. What I suggest is to start at a low level, and test it it. If it doesn’t spray smoothly, increase the thinner slightly and try again.
