HF Dust Collector Duct Size?
Forum topic by Adamal posted 11-16-2013 03:51 PM 1163 views 0 times favorited 4 replies Add to Favorites Watch
View Adamal's profile
Adamal
58 posts in 1999 days
11-16-2013 03:51 PM
I know this topic has been discussed to death, but after much searching and reading (including Bill Pentz’s site), I’m still not sure how to proceed.
My shop is about 18’ x 20’ with a Unisaw, router table, 6” jointer and miter saw as the main tools. I plan on running PVC for the main duct.
The consensus seems to be to use 6” PVC as close to the machines as possible. The HF collector has a 4” inlet though… must this be enlarged? I’ve read (somewhere) that the main should match the inlet size of the collector.
If 6” is the best way to go, what do I use to neck down to 4” at the collector?
Have any of you used a 4” main? What are you’re thoughts as this is what I had originally planned?
Thanks!
View b2rtch's profile
b2rtch
4861 posts in 3047 days
#1 posted 11-16-2013 03:56 PM
PVC is very expensive.
I used cheap duct from Lowes and HD, it works just fine with a Clear View
-- Bert
4986 posts in 2492 days
#2 posted 11-16-2013 04:41 PM
You need a certain velocity to keep the debris suspended as it moves through the duct. If you don’t, it falls out of the air stream and causes a clog. So, I wouldn’t recommend running 6” and choking it down to 4” at the blower. The blower impeller can probably be easily removed and replaced with a 6” shop built connection. Here’s what I don’t know: to use 6” ducting you have to have enough CFM to support it, and I have no idea if that unit will. Those that use 6” usually have a 2HP/12”impeller (+) blower. So get some info from those who have that particular DC before looking for 6” (and 6” is highly recommended since it allows a lot more air flow.) That said, you asked about 4” ducting, and that’s what I had for my first setup. I was impressed with the air flow I had, and it did what I wanted at the time. Just keep in mind that 4” will only allow ~400CFM or so flow, no matter what’s sucking air through it. But that may be enough to meet your expectations.
View thelt's profile
thelt
665 posts in 3378 days
#3 posted 11-16-2013 06:23 PM
I have 4” ducting going into a ‘Y’ on the DC the ‘Y’ has two 4” inlets that go to a 6” input on the DC. I get good air flow over a 15’ main line that drops to my surface planer, band saw, router table and oscillating sander. It works great for me.
-- When asked what I did to make life worthwhile in my lifetime....I can respond with a great deal of pride and satisfaction, "I served a career in the United States Navy."
Adamal
#4 posted 11-16-2013 07:17 PM
FWIW, I just bought the HF collector today. I now see that the main inlet is 5”. Then there’s a wye with two 4” ports.
