| Forum topic by Branlon | posted 357 days ago | 144 views | 0 times favorited | 1 reply | ![]() |
357 days ago |
A crooked 5/8” dowel hole in the bottom of my chair leg needs to be re-drilled. When I stick a 3 foot dowel rod in the hole and step back to see if the hole was drilled straight, the angle must be off by 10 degrees or more. The chair leg is Walnut and I would rather not replace it. If the hole is glued and plugged tight, will I be able to drill a new straight hole without the plug coming loose? Is there a better way to fix it? -- Branlon, Board Director, South Central Indiana |
