Delta saw blade not spinning
Forum topic by DaddyFixItAll posted 11-15-2013 07:01 PM 2952 views 0 times favorited 7 replies Add to Favorites Watch
View DaddyFixItAll's profile
DaddyFixItAll
4 posts in 1894 days
11-15-2013 07:01 PM
I have a 10” Delta table saw that was working great until I binded it up by rushing something and turned the wood a bit sideways. Anyway, it binded up and something “broke”. The motor still runs but the blade doesn’t turn. Is there a safety mechanism that kicked it out? I didn’t see one.
7 replies so far
View DeltaDaddy's profile
DeltaDaddy
52 posts in 1894 days
#1 posted 11-15-2013 07:15 PM
Did the drive belt snap?
-- Take it apart to see how it works
View longgone's profile
longgone
5688 posts in 3549 days
#2 posted 11-15-2013 07:19 PM
Is it direct drive or belt drive?
If it is belt drive, have you checked the pulleys and the belt?
View knotscott's profile
knotscott
8180 posts in 3616 days
#3 posted 11-15-2013 08:06 PM
Knowing the specific model of your saw, or at least the class of saw would be very useful to know.
DaddyFixItAll
#4 posted 11-17-2013 07:36 PM
It’s a Delta 36-300. 10” table saw. It looks like the drive is connected straight to the motor?
View pmayer's profile
pmayer
1032 posts in 3305 days
#5 posted 11-17-2013 07:47 PM
Even though it is considered a direct drive saw there is a small belt in there that has most likely broken.
DaddyFixItAll
#6 posted 11-17-2013 08:11 PM
Found it. It’s a belt drive. I wasn’t looking hard enough!
View bigblockyeti's profile
bigblockyeti
5319 posts in 1961 days
#7 posted 11-17-2013 08:12 PM
The small synchronous belt that runs from the armature drive pulley to the spindle driven pulley is probably broke. That’s best case scenario, worse is the end of the armature shaft snapped off.
