Good idea
Forum topic by DKV posted 11-15-2013 06:27 PM 892 views 0 times favorited 8 replies Add to Favorites Watch
View DKV's profile
DKV
3940 posts in 2410 days
11-15-2013 06:27 PM
-- This is a Troll Free zone.
8 replies so far
View JustJoe's profile
JustJoe
1554 posts in 1944 days
#1 posted 11-15-2013 06:35 PM
But he lost a few inches of vertical space now taken up by the part of the 3/8” bolt that sticks out of the old chuck, and the length of the keyless chuck. He’s also increased any runout that was already in his spindle by increasing the distance from the pivot point to the tip of the drill bit. If he wanted a keyless chuck, he could have just removed the old chuck from the DP and installed a keyless.
-- This Ad Space For Sale! Your Ad Here! Reach a targeted audience! Affordable Rates, easy financing! Contact an ad represenative today at JustJoe's Advertising Consortium.
View casual1carpenter's profile
casual1carpenter
354 posts in 2381 days
#2 posted 11-15-2013 07:12 PM
My flex shaft sander uses a collet and I wanted to use sanding heads from a drill chuck based system. I had a small machine shop operator thread and turn an arbor. He re-chucked (?) the assembled unit and corrected for runout. It might not be the perfect solution but $30. and a salvage chuck from an old drill as opposed to buying the additional sanding unit I thought was a good option for me.
View DKV's profile
DKV
#3 posted 11-15-2013 07:47 PM
JustJoe, how can I measure runout before and after? It is normally in the thousandths…right?
JustJoe
#4 posted 11-15-2013 08:11 PM
Dial indicator will work, either an old one or a cheap one:
http://littlemachineshop.com/products/product_view.php?ProductID=1593&category=
Just measure the runout with a piece of drill-rod in the original chuck, and then the same drill-rod in the added-on chuck. It should be thousandths,yes, although I once had a 17” Jet that had so much runout you could see the bit wobbling.
View AlaskaGuy's profile
AlaskaGuy
3912 posts in 2215 days
#5 posted 11-15-2013 08:14 PM
Never had a problem using the keyed chuck.
116906 posts in 3483 days
#6 posted 11-16-2013 12:08 AM
I’m trying to figure out why you would not just want a 1/2” keyless chuck in the drill press all the time,just change it out.
#7 posted 11-16-2013 12:12 AM
View cutworm's profile
cutworm
1075 posts in 2699 days
#8 posted 11-16-2013 12:31 AM
Good video Jim.
-- Steve - "Never Give Up"
