How would you cut this?
Forum topic by distrbd posted 11-15-2013 05:49 PM 3350 views 0 times favorited 13 replies Add to Favorites Watch
View distrbd's profile
distrbd
2252 posts in 2684 days
11-15-2013 05:49 PM
My wife has asked me to build another headboard for our queen size bed,my first thought was to make an actual size template with a 3/8” hardboard then use this template to cut a solid piece of jointed pine
My second thought was to imagine the design in four sections,make a template of one ,quarter of it,trace it on a piece of pine,cut it with a scroll saw,repeat ,cut until all four pieces are done,attach them together to make a one larger piece. it will not be exactly the same as the pic,but I don’t think it will be noticeable, the lace part would be soft pine ,1” thick.What other options can you think of?
-- Ken from Ontario, Canada
13 replies so far
16281 posts in 4456 days
#1 posted 11-15-2013 05:59 PM
Divorce.
View rance's profile
rance
4267 posts in 3398 days
#2 posted 11-15-2013 05:59 PM
Yes, the template only needs to be 1/4 of the whole. But this is too large(even 1/4 of it) for a scrollsaw. I’d use the 1/4 template and pencil it out on the whole sheet. Then cut with a jigsaw. Then comes the sanding. I’d try to get a handheld oscillating spindle sander to do the sanding.
View RussellAP's profile
RussellAP
3104 posts in 2524 days
#3 posted 11-15-2013 06:19 PM
I’m with CharlieM, divorce or CNC.
View casual1carpenter's profile
casual1carpenter
354 posts in 2713 days
#4 posted 11-15-2013 06:53 PM
distrbd, looks like an interesting but tedious project design. there is a repeating symmetrical pattern that my warped brain sees as this.
I would consider making the headboard cuts by first roughing out with a drill and jigsaw, then a pattern bit on the router. It still leaves you making an acceptable and usable pattern but only about 1/8 of the total. If you expanded the pattern beyond the cut and paste pick I posted it might be a significant help when flipping and aligning the pattern.
distrbd
#5 posted 11-15-2013 06:54 PM
LOL,Russell,Charlie she wouldn’t let go now,too many projects on the horizon,plus she considers us happily married ,I’m married,she’s happy(can’t remember where I heard that joke).
rance,I thought of using a jig saw but quickly gave up (b/c the rough uneven edges it will leave) but since you mentioned a os.sander,I’m rethinking it,it is a good option all of a sudden.
distrbd
#6 posted 11-15-2013 07:00 PM
Casual,that’s what I’m talking about,i/8th of the pattern is alright ,it will be small enough to cut on a scroll saw though as you said,tedious but can be done.cut 8 pieces ,flip and join together.
Thank you ,it helped me visualize it.
casual1carpenter
#7 posted 11-15-2013 07:29 PM
Glad it might have offered a different perspective. Just make sure you don’t mess up the flips as i did in the pick. I just noticed that something is wrong there. LOL, but it should still work.
View Dan'um Style's profile
Dan'um Style
14179 posts in 4220 days
#8 posted 11-15-2013 10:20 PM
auto-cad and half-lap joinery
distrbd
#9 posted 11-15-2013 10:55 PM
Casual,you are right ,#3 and #7 will need to be repeated as#1 and #5,, thanks for mentioning it.
Danum,I’m not good at neither,did learn autocad in 2001 but without practice I forgot everything by 2003.
Half-lap joinery will work but probably more work ,this would be too big of a project ,maybe on a smaller scale I would consider it.
117417 posts in 3815 days
#10 posted 11-15-2013 11:09 PM
Of course CNC would be great or perhaps a multi tool or even just painting the pattern on other than those ideas I think “casual “has the best approach ,it may be possible to just divide it on the four vertical lines and still use a scroll saw. Guessing the pattern is no more than 1/2” thick and probably closer to a 1/4” I don’t think I would use pine for making it ,I would be more incline to use something like MDO sheet goods. I would still experiment with a jig saw(if you have a good one) to see how well it works on sheet goods pre-drilling and using a good blade.
View Luke's profile
Luke
290 posts in 2924 days
#11 posted 11-15-2013 11:27 PM
Perhaps, you could do a hardboard pattern. Rought cut a with jig saw, and pattern bit on router to get a cleaner edge.
Are you dedicated to using pine?
distrbd
#12 posted 11-16-2013 12:07 AM
There are two reasons behind using pine,first reason,it is easier to cut with the scroll saw (as I had planned) specially since it is going to be 1” thick.
My second reason was,my wife inevitably will paint everything I build,but with some persuasion(begging) she can stop or at least postpone it for a long time.it’s just a shame to use white birch or cherry if the thing is going to be painted.
View sparks's profile
sparks
62 posts in 3326 days
#13 posted 11-16-2013 04:53 AM
They make really good jigsaw blades that leave an almost sand free edge if you take your time. I think jigsaw is the way to go the round over the edges with a router. However you go looks to be a great project.
-- Sparks
