How would you make this cut?
Forum topic by UncannyValleyWoods posted 11-15-2013 03:26 AM 1030 views 0 times favorited 11 replies Add to Favorites Watch
View UncannyValleyWoods's profile
UncannyValleyWoods
542 posts in 1767 days
11-15-2013 03:26 AM
I thought about doing it with a mortiser, but it won’t leave a clean surface due to the tap at the end of the bit. Can’t do it on the table saw, since it will inevitably leave the curve of the blade.. I could clean it out with a chisel, but I’m curious if anyone has any thoughts before I go butchering up good wood.
-- “If Jesus had been killed twenty years ago, Catholic school children would be wearing little electric chairs around their necks instead of crosses.” ― Lenny Bruce
11 replies so far
View GOOD LUCK TO ALL's profile
GOOD LUCK TO ALL
418 posts in 1631 days
#1 posted 11-15-2013 03:34 AM
I say no matter what your going to have to do some chisel work.
I would set up a router and some stops, then all you have to do is clean up the bottom corners.
(rout 1 sied, turn, rout the other side.) May have to do a couple of passes on each side to get the width.
UncannyValleyWoods
#2 posted 11-15-2013 03:36 AM
Ahhh…I hadn’t considered the router… Good call.
View ShaneA's profile
ShaneA
6889 posts in 2502 days
#3 posted 11-15-2013 03:43 AM
That shape could be obtained through a glue up.
9941 posts in 3551 days
#4 posted 11-15-2013 03:44 AM
I did two of these in end grain this week. I used a dozuki
for half and then chisels for the rest. If you have to do more
than a few, a router template is a good way to remove the
waste and reduce the chiseling down to just a few cuts.
View jordanp's profile
jordanp
1086 posts in 1844 days
#5 posted 11-15-2013 03:45 AM
I’ve always done that type of cut with a tenon/dozuki hand saw and a chisel
-- J. Palmer Woodworks - Rockwall TX -I woke up this morning thinking “man, I really hope someone posted some soul scarring sh*t on LJs today.” -- - Billy
UncannyValleyWoods
#6 posted 11-15-2013 04:14 AM
All good ideas… I only need four, so a little dozuki action will likely be in my future..
View waho6o9's profile
waho6o9
8099 posts in 2480 days
#7 posted 11-15-2013 04:23 AM
I purchased a Dozuki from Lee Valley and can’t believe how
effective it works. It makes a thin cut wicked quick.
UncannyValleyWoods
#8 posted 11-15-2013 06:57 AM
Yep, I’ve got one…I was just afraid it wouldn’t work so well, since I’m not going all the way through the piece. See, I’m must scooping out a corner… However, I can easily cut at a diagonal to my stopping points, then chisel out the middle.
View VikArggo's profile
VikArggo
2 posts in 1557 days
#9 posted 11-15-2013 09:01 AM
I would advise you try Dozuki. It may well be used for any type of wood
-- http://www.aquar-system.com/
View Cubby's profile
Cubby
48 posts in 4042 days
#10 posted 11-15-2013 09:57 AM
How about a morticing bit in the drillpress? The piece would have to be firmly held in a vise and the table would have to be dead square to the bit. Or, if you do not have a morticing bit,just drill a hole, mark the cutout with a marking knife and finish with sharp chisel.
-- Ron Baird, Pennsylvania, WINDGAP375@aol.com "WORK HARD, BE GOOD, HAVE FUN"
View bondogaposis's profile
bondogaposis
4597 posts in 2255 days
#11 posted 11-15-2013 11:44 AM
Router would a good way, also you could use a saw to get some of it and waste the rest w/ Forstner bit on the drill press and clean up w/ chisel.
-- Bondo Gaposis
