TABLE SAW MOTOR *FILTER*
Forum topic by HillWilly posted 11-15-2013 01:59 AM 951 views 0 times favorited 5 replies Add to Favorites Watch
View HillWilly's profile
HillWilly
54 posts in 2072 days
11-15-2013 01:59 AM
Topic tags/keywords: table saw motor 10322171 craftsman
I installed a 1hp. motor on my 103.22171 but it is not the sealed type motor and every once in a while it starts to act up so I have to blow the dust out of the housing and it’s fine again. It is a pump type motor. I went to HD and bought a pack of those filter covers that go over a wet/dry vac filter, {they are held on with a band of some sort] and fashioned a “hairnet” cover for the motor and it works great.
My question is, can the fan inside the motor be reversed so that the inlet and filter is on the dumb end, instead of the business end???? This sure would make things easier!!!
-- ...and whether or not it is clear to us, no doubt the universe is unfolding as it should...DESIDERATA...Max Ehrmann
5 replies so far
View Grandpa's profile
Grandpa
3259 posts in 2639 days
#1 posted 11-15-2013 02:39 AM
I think not but you will have to disassemble the motor and see if parts are welded in place or held by something else. I think you will find them fixed. Does the motor cool well with the filter? Heat is a bad thing for motors but I suppose you don’t run it continuously for hours.
View Rick's profile
Rick
9414 posts in 2996 days
#2 posted 11-15-2013 02:46 AM
Agree With “Grandpa”’ I think you’re asking for trouble IE Excess Heat!
-- LIFE is what happens when you're planning on doing Other Things!
View Tedstor's profile
Tedstor
1643 posts in 2596 days
#3 posted 11-15-2013 02:48 AM
The commo guys in my USMC unit used stockings (panty hose) to keep sand/dust out of the radio gear. Seemed to work oK. And heat wasn’t an issue, even in 110*+ heat.
I have no idea where they got the pany hose…....I was afraid to ask. LOL. But it worked.
Just an idea.
Grandpa
#4 posted 11-15-2013 03:00 AM
When I was in the service they didn’t want us to even paint an electric motor. Makes them overheat. I have just tried to stick with that over the last 45 years.
HillWilly
#5 posted 11-15-2013 03:33 AM
Thanx, You are probably correct Rick and Grandpa, if the motor ran continuously but that is hardly the case. Specially in my poorly heated shed.
