--- Walnut Countertop growth rings orientation ??? ---
Forum topic by irish620 posted 11-14-2013 01:14 AM 7495 views 0 times favorited 7 replies Add to Favorites Watch
View irish620's profile
irish620
37 posts in 2276 days
11-14-2013 01:14 AM
Hey Guys,
I am making a walnut countertop that will be attached to a knee wall . I bought kiln dried 8/4 flat sawn material, since the customer wants that exact look. The planks have now been jointed and milled down to 96’’ x 18’’ (4-5’’ widths] x 1.5’’. Of course the grain pattern looks the best with all the growth rings going in the same direction. Do you think its crazy to disregard the alternating growth rings pattern, for the sake of the look ? The top will be installed here in San Diego, which is dry to begin with, and I plan on finishing the whole top evenly coated. Since its on a knee wall, as a breakfast bar, it will be supported with brackets and elongated holes to allow for movement. How would you glue up this countertop ?
7 replies so far
View StumpyNubs's profile
StumpyNubs
7578 posts in 2768 days
#1 posted 11-14-2013 01:33 AM
No breadboard end I assume? Some say the benefit of alternating the growth rings in minimal. It looks like your boards are fairly narrow and reasonably thick. As long as you let them acclimate in the same climate for a bit before you do the final milling, I think it will be just fine.
-- Subscribe to "Stumpy Nubs Woodworking Journal"- One of the crafts' most unique publications: http://www.stumpynubs.com/
irish620
#2 posted 11-14-2013 01:41 AM
No breadboard, customers want modern look. They are 1.5 thick x 5’’ wide right now and will just skim them to level the surface before final middle seam/glue up. Just afraid of getting that phone call next summer that their bar is warped ???!
StumpyNubs
#3 posted 11-14-2013 01:48 AM
I am assuming they stock is kiln dried well, and has acclimated to the climate of the house. If you can let it actually sit in the house for a few days, that would be great. But as long as your shop isn’t significantly different, it should be fine. It looks like you have some nice long brackets, maybe you can drill them and use lots of screws if you want to be sure. But I think you should be fine.
View Steve Peterson's profile
Steve Peterson
371 posts in 3049 days
#4 posted 11-14-2013 02:23 AM
You might want to elongate the holes in the metal brackets, so you don’t get a call next summer that their bar is cracked. :)
-- Steve
View Picken5's profile
Picken5
250 posts in 2659 days
#5 posted 11-14-2013 04:00 AM
I did a similar project in my home using 4/4 makore trimmed in walnut. I glued the boards to a piece of 3/4” MDF that I had first put down as a base. I also screwed the makore to the MDF — angled the screws at an angle so they’d be invisible. I ignored the growth rings, but I was obviously concerned about warping. I also made sure I finished the underside so any changes in moisture content would be the same throughout — well, as much the same as I thought I could control. It’s been almost 3 years now and no warping whatsoever.
-- Howard - "Time spent making sawdust is not deducted from one's lifetime." - old Scottish proverb
View pintodeluxe's profile
pintodeluxe
5623 posts in 2780 days
#6 posted 11-14-2013 04:24 AM
I think you will be fine. If it were a 40” wide dining table I might be concerned. As it is, just orient for best aesthetics.
irish620
#7 posted 11-14-2013 05:53 AM
In the past, I haven’t paid much attention to growth rings but this is a countertop/bar that will see a lot of
use and it is right next to a kitchen sink. So, my original thought was since they are smaller width boards of thicker
dimension, warping/cupping shouldn’t be a problem. But as I was laying out the boards for best look, I realize they were all going in the same orientation. Kinda thru up a red flag to seek advise
