Need help with log bench leg options
Forum topic by bigblockyeti posted 11-13-2013 09:02 PM 5795 views 0 times favorited 6 replies Add to Favorites Watch
View bigblockyeti's profile
bigblockyeti
5286 posts in 1924 days
11-13-2013 09:02 PM
I’ve completed the milling and sanding of the main half log making the bench seating surface, but I don’t know what to do about legs and I need some recommendations. It’s already around 300lbs so I’m not worried if it ends up being heavier. I do want to make sure that it will sit flat, so either three legs or four with one adjustable foot. Any ideas?
View mahdee's profile
mahdee
4024 posts in 1971 days
#1 posted 11-29-2013 03:52 PM
300 LB?? If you have a lathe, use similar logs about 4-6 inches; round one end to about 2-3/4. Saw the tenons vertically. Boar a whole at about 15 degree 3” deep on the bench. Place wooden wedges inside the saw cuts on tenons and hammer the legs in. Alternative is using pre-fabricated cast iron or steel legs. :(
-- earthartandfoods.com
View Monte Pittman's profile
Monte Pittman
30064 posts in 2542 days
#2 posted 11-29-2013 04:56 PM
I would use 4 legs for that heavy. you can always sand off the ends a little to level it.
View richardwootton's profile
richardwootton
1701 posts in 2159 days
#3 posted 11-29-2013 10:41 PM
I agree, I’d use 4 legs. Is that spalted maple?
-- Richard, Hot Springs, Ar -- Galoot In Training
View Don W's profile
Don W
19018 posts in 2771 days
#4 posted 11-29-2013 10:47 PM
http://lumberjocks.com/donwilwol/blog/23482
see if this helps.
View redSLED's profile
redSLED
790 posts in 2096 days
#5 posted 11-30-2013 01:34 AM
I’m very partial to modern metal leg designs juxtaposed with live edge/log benches. Some ideas:
bigblockyeti
#6 posted 12-03-2013 04:11 PM
It is spalted maple, silver? I think. I am leaning more toward the four legged option. I do have a lathe and several different sized self feed bits in the 2” – 4” range. The other thought I had that I’ve seen is two half logs coped to the profile of the main bench log or the main log coped to them. Seems like it would be a tremendous amount of wood to remove with any degree of precision. I do like the modern look, but I have several smaller logs on hand, acrylic and steel I don’t have on hand right now.
