Need drive belt for PC 125 31/4" power planer
Forum topic by root posted 11-13-2013 05:34 PM 1530 views 0 times favorited 6 replies Add to Favorites Watch
View root's profile
root
4 posts in 1840 days
11-13-2013 05:34 PM
I have a Porter Cable Model 125 3 1/4” power planer that needs a new drive belt. Have checked with PC and drive belt is no longer available. Does anyone know of a source that might have parts available? I appreciate all your help and knowledge and know someone will know of a source. Thanks a bunch.
View JustJoe's profile
JustJoe
1554 posts in 2001 days
#1 posted 11-13-2013 05:36 PM
Got a pic of the old one, maybe some measurements?
-- This Ad Space For Sale! Your Ad Here! Reach a targeted audience! Affordable Rates, easy financing! Contact an ad represenative today at JustJoe's Advertising Consortium.
View pintodeluxe's profile
pintodeluxe
5618 posts in 2776 days
#2 posted 11-13-2013 06:29 PM
Toolpartsdirect.com can help with schematics, but the part is obsolete. You will either have to find a match from an industrial supplier of belts, or else replace the planer.
View ZacD's profile
ZacD
34 posts in 1722 days
#3 posted 11-15-2013 04:44 PM
Could you offer some more info on the belt? I’ve done some pretty extensive parts hunting before. May even have one that will work.
  • A picture if you can
  • Type of belt
  • width of the belt
  • length of the belt (i assume it is broken and you can measure it flat)
  • if it is a ribbed belt / multi Vee belt, how many ribs does it have (this type of belt has grooves running the full circular length of the belt)
Failing all searches, depending on how the pulleys are installed, you could probably swap them out for Vee pulleys and get a link belt for it.
View root's profile
root
#4 posted 11-21-2013 06:38 PM
ZacD: Thanks for the info. Here is what I have for specs.
Width of belt-9/16” 7 ribs that look like “V” shaped and approx. 10 1/2” long
Tried a Bosch belt from a 3” planer but was about 1/16” too long and another planer but was about the same too short and put too much pressure on the drive axels. I appreciate everyone’s feedback. Thanks.
JustJoe
#5 posted 11-21-2013 06:55 PM
You’re sure it’s seven ribs and not six?
Edit: And what was the bosch belt that was 3/16” too long? Do you have a stock or model # for that belt?
View ZacD's profile
ZacD
#6 posted 11-21-2013 10:44 PM
I’m having no luck finding a belt under 18 inches with 7 ribs. Count them again to be sure. If it is 6 ribs, this belt will work, although a bit pricey.
