HF DC
Forum topic by MrRon posted 11-13-2013 05:27 PM 881 views 0 times favorited 5 replies Add to Favorites Watch
View MrRon's profile
MrRon
4714 posts in 3208 days
11-13-2013 05:27 PM
I finally got my HF 1-1/2 horse dust collector up and running. I scrapped most of it and kept only the motor/fan assembly. I have it hooked up to my cabinet saw and blowing to the outdoors by way of a chip separator barrel. Since most of the sawdust is fine, not much settles in the barrel. There seems to be too much suction resulting in a lot of sawdust being blown outdoors. Upon start-up, I can hear larger particles going through the fan. The barrel I’m using is 55 gallon with inlet/outlet located 180° apart. The barrel inlet blows straight down into the barrel. I’m not sure if I can trap sawdust from a saw. I’m using 4” duct.
5 replies so far
View b2rtch's profile
b2rtch
4851 posts in 3013 days
#1 posted 11-13-2013 05:32 PM
You need a Thien separator in your trash can and a cyclone lid
Check this link:
https://www.google.com/#q=thien+separator
-- Bert
View crank49's profile
crank49
4030 posts in 2935 days
#2 posted 11-13-2013 06:12 PM
You should have the inlet coming in along the outer edge of the barrel and blowing tangent to the side.
Either coming horizontal into the side, or through the top then a 90 degree ell to turn it horizontal and tangent. The outlet should be coming straight out the center and the pipe should be inside the barrel about 6” to 8”.
The Thein baffle everyone talks about basically does the same thing except it adds a baffle plate between the top inlet space and the bottom collection space. They work, but I think a properly built drum with regular inlets like I described above will work almost as well and is much easier to build.
Your drum with the inlet blowing down into the barrel will stir up the dust that is trying to settle to the bottom and encourage it to go out the outlet. If you are going to have a collection barrel you might as well make it collect something.
b2rtch
#3 posted 11-13-2013 06:21 PM
The baffle in the Thein baffle prevents the dust from coming back up and through the exit.
You need the baffle.
The thien baffle is easy to build
-- Bert
MrRon
#4 posted 11-14-2013 05:23 PM
I’m going to build a Thein baffle, but of a different design because the barrel I’m using is necked down at the top.
b2rtch
#5 posted 11-14-2013 05:38 PM
OK
-- Bert
