Do screwdrivers defy the laws of physics?
« back to Hand Tools forum
Forum topic by Craftsman on the lake posted 11-13-2013 12:54 PM 3901 views 0 times favorited 46 replies Add to Favorites Watch
2768 posts in 3367 days
11-13-2013 12:54 PM
Topic tags/keywords: question humor
A question was asked of my years ago and it always stuck with me.
Why is it that when you use a longer handle screwdriver you get more turning power?
Explanation of question. If you have a ratchet with a socket on it and you need more torque you get a longer handled ratchet or add an extension to the handle like a pipe. With a long enough handle the bolt or the ratchet will break. The longer handle acts as a longer lever. With a screwdriver a thicker handle will do the same thing but also, as long as you can get a good grip, a longer screwdriver will give you a similar effect. Got a stubborn screw? Get a longer driver. Even with two screwdrivers of the same handle size and bit size, one a foot long and the other a short tight space one. The longer one will turn a tough screw easier.
To me, it doesn’t seem to follow the mechanical advantage rules that we know of simple machines. There must be some explanation. I don’t think the laws of physics apply to all things but screwdrivers. Then again, I ask myself, “Are there more important things to think about than this?”.
46 replies so far
View Handtooler's profile
1511 posts in 2062 days
#1 posted 11-13-2013 01:23 PM
And, some of the larger screwdrivers have wrench flats just below the handle so one might get back into the physics realm by extending the leverage horizonially out the side, Huh?
-- Russell Pitner Hixson, TN 37343
View deezldub's profile
14 posts in 1790 days
#2 posted 11-13-2013 01:24 PM
The way it was explained to me (servicing Japanese photo processing equipment for 20+ years) the longer shaft screwdrivers allow you to keep more pressure on the tip by leaning into the screwdriver, and it builds up rotational torque to help break the screw loose. It would usually just “pop” loose with the longer drivers and once you got it started you were good to go, We were issued both 8” and 12” philips (JIS standard which are a tighter fit) # 2 drivers that worked wonders for getting chemically crusted screws to break free without camout.
-- Steve
View bigblockyeti's profile
5051 posts in 1650 days
#3 posted 11-13-2013 01:24 PM
You can wrap your hand more completely around a small handle with a long shank given the distance you have between your hand and the work piece vs. having the same sized handle and a shorter shank. The psychological difference is there as well; you’re less likely to bear down on a smaller handled screw driver (most also have a shorter shank) due to the likelihood you’ll slip and hit your hand on the work piece. Metal can sharp, wood can be too and our sense of self-preservation tends to kick in and prevent us from hurting ourselves, especially when our experience tells us there’s probably a better option.
404 - Not Found
2544 posts in 2899 days
#4 posted 11-13-2013 01:30 PM
If this was on “Call My Bluff” (a terrible British game show where three explanations are offered by eminent intellectuals to some obscure puzzle), I would go with answer 2, rotational torque advantage.
View jonah's profile
1624 posts in 3228 days
#5 posted 11-13-2013 01:46 PM
The answer is that you don’t get more turning power from a longer screwdriver. You get a bigger handle that you can apply more downward force and torque to.
If you had a stumpy screwdriver with a huge handle, you’d see the same effect.
View Tim's profile
3755 posts in 1891 days
#6 posted 11-13-2013 01:50 PM
There was a post on the Lost arts press blog about this. From an 1880 magazine article or something, and a few engineers chimed in.
View Tennessee's profile
2801 posts in 2444 days
#7 posted 11-13-2013 01:52 PM
This is like a “mindworm”, something in your head you can’t quite figure out. I’ve imagined the scenario, and you are right about length, but shorter screwdrivers usually have somewhat shorter handles, and your body and arm is more cocked, eliminating some torque. I’m not really buying that rotational torque thing, where the shaft might actually act like a spring, wind ever so slightly and then add torque.
Long handle, long arm torque = more advantage.
View HorizontalMike's profile
7749 posts in 2844 days
#8 posted 11-13-2013 02:08 PM
I would suggest that the longer shaft has more flex than the shorter shaft. When turning the longer shaft, some of the energy you are exerting on the screwdriver by twisting, is stored as ”potential energy”. When the screw/bolt finally “snaps” loose, this ”potential energy” is converted back to ”kinetic energy” thus giving a longer (time) push/twist in loosening the screw/bolt. This can be interpreted by some as being more powerful, though the same amount of total energy is exerted in both short and long handled screwdrivers.
That’s my 2-cents anyway…
View joeyinsouthaustin's profile
1294 posts in 2002 days
#9 posted 11-13-2013 02:11 PM
I think the answer is based more in ergonomics than in physics…. Send you question into the Mythbusters!!
-- Who is John Galt?
117028 posts in 3507 days
#10 posted 11-13-2013 02:20 PM
It all seems “screwy” to me :)
-- wood crafting & classes
View Gene Howe's profile
Gene Howe
10242 posts in 3358 days
#11 posted 11-13-2013 02:40 PM
While I have benefitted from the same phenomenon, I have no answer as to why it works.
OTOH, I can answer your final question: Probably, but where’s the fun in that?
View ZacD's profile
34 posts in 1689 days
#12 posted 11-14-2013 04:42 PM
It has always been my impression that longer screw drivers also have larger shanks, and sometimes larger handles (this is apparent in your photo). So they would inherently carry more torque than shorter screw drivers, which typically have much thinner shanks. On another note, a larger shank is less likely to deform and twist against you and the handle holding it will also be less likely to deform and twist, because the shank has more surface area for the handle to hold.
The only other way it works is if it is in your head. Nothing has yet been discovered to defy any current laws of physics.
View jumbojack's profile
1673 posts in 2554 days
#13 posted 11-14-2013 04:52 PM
It is another one of Gods gifts to man. Siphon is another that comes to mind.
View Danpaddles's profile
573 posts in 2242 days
#14 posted 11-14-2013 05:04 PM
I’ve broke a few laws in my life, but whenever I’ve tried to break the laws of physics, it never ended well.
If the longer shafted screwdriver works better, it is because the rotational force is closer to your body, where you can really put the torque to it.
No laws of physics have been broke. Now y’all move along, nothing more to see here.
-- Dan V. in Indy
16273 posts in 4148 days
#15 posted 11-14-2013 05:14 PM
I have often wondered the same thing.
I don’t have the answer, but I do not believe it has anything to do with the bigger shaft/bigger handle/better grip theory some have suggested. I make this statement based on personal experience, and the five years I spent selling Craftsman tools part-time when I was in high school and college.
Take two Craftsman slotted screwdrivers. model #’s 41581 and 41582. They are identical in shaft size, tip size, and handle size, but one has a 4” shaft and the other a 9” shaft. The one with the 9” shaft will definitely turn a tight screw easier than the shorter one, even though all other factors are equal.
I believe HMike is sort of onto the right answer. I think the longer shaft flexes rotationally as you apply pressure, building up leverage. In other words, the force of the metal shaft trying to return itself to its normal shape is added to the rotational force applied by your hand.
showing 1 through 15 of 46 replies
