Got clamps?
Forum topic by MT_Stringer posted 11-13-2013 04:37 AM 1461 views 0 times favorited 24 replies Add to Favorites Watch
View MT_Stringer's profile
MT_Stringer
3168 posts in 3226 days
11-13-2013 04:37 AM
Topic tags/keywords: tip clamp
You can never have too many clamps! Just sayin’! :-)
24 replies so far
117090 posts in 3572 days
#1 posted 11-13-2013 04:50 AM
Yep this is true.
View ColonelTravis's profile
ColonelTravis
1768 posts in 1889 days
#2 posted 11-13-2013 05:04 AM
Written on my tombstone: He never had enough clamps!
View darthford's profile
darthford
601 posts in 1919 days
#3 posted 11-13-2013 05:12 AM
Stringer that knot looks like its about to fall out you better get a clamp on that.
View Handtooler's profile
Handtooler
1553 posts in 2127 days
#4 posted 11-13-2013 09:57 AM
Not quite enough, huh? Add a couple of longitudinal cauls to complete the flattening process. Ha-ha. I like the idea of using the pipe clamp through the dog holes. I’ll be sure to use that in my fiture.
-- Russell Pitner Hixson, TN 37343 bassboy40@outlook.com
View BENTWOOD's profile
BENTWOOD
373 posts in 1777 days
#5 posted 11-13-2013 01:32 PM
You Sir are a “Clampaholic” :)
-- http://www.bentwoodjewelrydesigns.com
View bigblockyeti's profile
bigblockyeti
5112 posts in 1716 days
#6 posted 11-13-2013 01:56 PM
Just bought a few of the cheap 12” harbor freight quick clamps for $1.99 each. Too often I find myself need to do a light clamping job and grabbing a clamp way to big for what I need. I guess I’ll see how these work out, they’re okay, but not great so far.
View Tennessee's profile
Tennessee
2872 posts in 2509 days
#7 posted 11-13-2013 02:00 PM
bigblock I own about thirty of those cheapie HF short clamps, all 6” and 12”. Anything longer and it’s just cheap metal.
I use them for all my small glueups. They work great. For the larger stuff I have an army of hunky Irwins.
View Bogeyguy's profile
Bogeyguy
548 posts in 2063 days
#8 posted 11-13-2013 02:15 PM
After breaking about a half dozen of the HF clamps, I finally declared to myself that they are JUNK.
-- Art, Pittsburgh.
View helluvawreck's profile
helluvawreck
31040 posts in 2862 days
#9 posted 11-13-2013 02:32 PM
You’re right about that. I wish that I owned a big clamp company
helluvawreck aka Charles
View 8iowa's profile
8iowa
1580 posts in 3756 days
#10 posted 11-13-2013 02:33 PM
“You can never have enough clamps”.
Sometimes when a statement is made often enough, it takes on the aura of truth, when that may not be the case!
Two years ago I attended Graham Blackburn’s class at the WIA conference in Covington, KY. He introduced us to the sliding butt joint. He said that when you joint boards on a power jointer the surface consists of thousands of microscopic “scallops”, and when you place two edges together it would be a miracle if they all matched up.
Blackburn explained, that at a class he taught at the Marc Adams school, he and the class attendants used a hand plane to smooth the previously jointed edges. Then after applying the glue, he placed the edges together, slid them back and forth a couple of times, and then announced that it was time for the lunch break.
“What about the clamps” the class up-roared in unison. We don’t need clamps said Blackburn, going on to say that “you can never have enough clamps” is a cliché fostered on us by the makers and sellers of clamps.
Sure enough, when they returned from lunch, all the joints were perfectly glued.
View BigMig's profile
BigMig
439 posts in 2608 days
#11 posted 11-13-2013 03:14 PM
Yeah, there’s something about the friction between glued parts that allows the glue to (seemingly) set up faster. Friction makes heat and that accelerates the process? Not sure myself, but I’ve seen it work, sometimes to my chagrin.
-- Mike from Lansdowne, PA
bigblockyeti
#12 posted 11-13-2013 03:15 PM
I know these won’t hold up as well as my besseys, but getting 7 of them for half the price of one 12” bessey k-body, I thought they’d at least be worth looking into. Again, I know they won’t offer nearly the power of a quality clamp, but I only need them for lighter jobs where I need several clamps, but not necessarily a lot of clamping force.
MT_Stringer
#13 posted 11-13-2013 04:16 PM
I have a dozen or so of the HF 6 inchers and 6 or 8 12 inchers. They work great for the light work. I switch to the heavier clamps for glue ups like cutting boards or edge gluing boards.
I modified some of the clams so I could stick them through the table.
I use the heavier clamps for edge cluing.
ColonelTravis
#14 posted 11-13-2013 04:39 PM
My problem with the blue handle HF clamps are the handles that strip off and just spin around and around. Not every one if mine has done that but the ones that have it was way too easily, didn’t tighten hardly at all before they came loose.
View pintodeluxe's profile
pintodeluxe
5654 posts in 2808 days
#15 posted 11-13-2013 04:45 PM
What are you doing to that poor board in the top photo?
At any rate, it’s not going anywhere.
