Scroll saw blades for marquetry
« back to Scrollsawing forum
Forum topic by Boris posted 11-13-2013 02:17 AM 5584 views 1 time favorited 17 replies Add to Favorites Watch
View Boris 's profile
Boris
190 posts in 2911 days
11-13-2013 02:17 AM
Topic tags/keywords: question blade
Hi, guys
I am interesting in double bevel marquetry using a scroll saw, I would like to know what will be your recommendation for blades.
Thanks
Regards
17 replies so far
View doordude's profile
doordude
1085 posts in 2979 days
#1 posted 11-13-2013 05:52 AM
just had a class, and was told to use “Olsen- 3/0 blades
i’m learning and a long way to go…
View TorxNut's profile
TorxNut
58 posts in 1893 days
#2 posted 11-13-2013 06:35 AM
Flying Dutchman and Olsen are both well regarded for their scroll saw blades. You can see what FD offers here: http://www.mikesworkshop.com/blades.htm and a chart of Olson blades here: http://www.olsonsaw.net/lib/yhst-16765698503918/ScrollChart.pdf
One thing to keep in mind is though the spiral blades look like a great idea, they can be hard to follow a line with. The reverse tooth blades cut well with very little splintering.
Hope this helps,
Bill
View PaulDoug's profile
PaulDoug
1535 posts in 1700 days
#3 posted 11-13-2013 04:11 PM
Mike’s workshop is a great place to deal. If you send him an email, or call him, he will send you couple blades to try, for free. Just tell him what you are trying to accomplish and he will send a couple blades that he would recommend.
View DrDirt's profile
DrDirt
4424 posts in 3739 days
#4 posted 11-13-2013 07:27 PM
For Marquetry – I use a 2-0 skip tooth
There are many fine blades – some of which may be better like doodude usin 3-0.
I took a class to learn marquetry, and we used 2-0 there, and I never bothered to really try a lot of other blades, since the olsen 2-0 worked great.
I find I am working at a 7degre tilt
If you use a “fatter” blade – - that is cutting a wider kerf you will have to increase the angle.
The thinner the cut – - the less bevel you need to make your piece fit like a cork into the background
View alohafromberkeley's profile
alohafromberkeley
257 posts in 2401 days
#5 posted 11-13-2013 07:59 PM
MikesWorkshop has a sampler pack of FD blades- a good way to try a few and see what you like. He’s friendly and knowledgeable.Great prices for great blades- he even threw in a couple free blades that weren’t in sampler. Can’t go wrong with FD or Olson blades.
-- "After a year of doing general farmwork, it was quite clear to me that chickens and I were not compatible"-George Nakashima
Boris
#6 posted 11-13-2013 11:51 PM
Thank you guys
So 2-0 and 3-0 are blades sizes.
Regards
View Jim Finn's profile
Jim Finn
2656 posts in 2918 days
#7 posted 11-14-2013 01:18 AM
I do over 350 double bevel inlayed images a year and I do them all with Flying Dutchman Polar #5 blades.
-- Website is No PHD just a DD214 and a GED https://craftingcouple.com/
View shipwright's profile
shipwright
7980 posts in 2794 days
#8 posted 11-14-2013 04:27 AM
The finer the marquetry you want to cut, the finer the blade you should use. I use 2/0, 30 tpi and 60 tpi blades but I’m using a chevalet, not a scroll saw and I’m square cutting, not DB. I find that they are fine enough without being overly prone to breakage.
DrDirt
#9 posted 11-14-2013 03:01 PM
To get your tilt right, take two pieces of veneer – - maybe 2-3 inches square, and cut a 1 inch circle
Your top piece should fit the bottom like a cork – - if there is a gap, increase the tilt. if the plug wont lie flush, decrease the tilt.
Also the Thicker the veneer – - the flatter the angle.
I tilt to the left (so table running from 8’oclock-2 oclock.
The keeper piece on top. and always on the left side of the blade.
Just try some stuff out – - simple shapes with scraps of veneer
Boris
#10 posted 11-15-2013 03:42 AM
I did a leaf today and it came better than my previous attempt, still a long way to go, the worst part was the entry hole
Thank you all for your replays I appreciate it .
Regards
Jim Finn
#11 posted 11-15-2013 09:14 PM
Boris:.........Are you drilling the entry hole at an angle? I drill mine at approximately six degrees and the entry hole then does not show.
Boris
#12 posted 11-15-2013 10:56 PM
Yes Jim, I am but I think the drill bit is to big, I am going to buy pin drill driver that might help.
Thanks
Regards
DrDirt
#13 posted 11-15-2013 11:13 PM
Boris – when I was doing this we were just poking a hole through the veneer wih an awl.
It seemed that the awl did more “spreading the wood” than ploughing out a hole, so that when you pressed it back flat you could nearly burnish the hole away. Just tapping with the butt of a chisel.
Boris
#14 posted 11-15-2013 11:54 PM
Hi Dave, I am using 3/32 thick veneer
Thanks
Regards
View Ironman132's profile
Ironman132
9 posts in 1603 days
#15 posted 07-31-2015 12:12 AM
Great info Dr Dirt!
-- Larry
