Ridgid planer update and question
Forum topic by Sandra posted 11-12-2013 05:43 PM 901 views 0 times favorited 11 replies Add to Favorites Watch
View Sandra's profile
Sandra
7207 posts in 2073 days
11-12-2013 05:43 PM
I posted last week about my Ridgid planer and the seized screws holding the blades in place.
By the end of it, I successfully removed one of the screws, but the other two broke off. The broken ones are on the same blade, but I was able to tightly seat the blade nonetheless.
I contacted Ridgid, and they told me that to have it serviced, I need to bring it to the nearest service centre which is over an hour’s drive away. They will however have it delivered back to me.
So no planer until I’m able to get it there, then they would presumably remove the screw shafts and send it back. (trust me, I tried to extract them myself)
I’m sorely tempted to fire it up and run it anyway.
Any thoughts?
-- No, I don't want to buy the pink hammer.
11 replies so far
View Monte Pittman's profile
Monte Pittman
29226 posts in 2336 days
#1 posted 11-12-2013 05:46 PM
If there is any chance the blade is loose, don’t do it. Really bad things can happen.
View waho6o9's profile
waho6o9
8190 posts in 2575 days
#2 posted 11-12-2013 05:50 PM
Don’t.
View CFrye's profile
CFrye
10192 posts in 1838 days
#3 posted 11-12-2013 05:56 PM
Understand your frustration Sandra. Not worth the risk. Would you let another family member use it knowing it ‘might be OK’?
-- God bless, Candy
View b2rtch's profile
b2rtch
4861 posts in 3046 days
#4 posted 11-12-2013 06:23 PM
Could be time to buy a Shelix head to install in your planer, they are expensive but they are very good and they last you a lifetime
-- Bert
View dhazelton's profile
dhazelton
2767 posts in 2295 days
#5 posted 11-12-2013 06:37 PM
You can drill them out yourself if you are extremely careful. Or you could get some ez outs – that’s probably how they will do it.
http://www.amazon.com/piece-Easy-Screw-Bolt-Extractor/dp/B0002UJNWE
Sandra
#6 posted 11-12-2013 07:40 PM
Well, I guess I already knew the answer. Point taken.
dhazel- I did try the ez outs. That’s what got the first one out, the others I can’t reach…
View JL7's profile
JL7
8662 posts in 2963 days
#7 posted 11-12-2013 08:24 PM
Sandra….I had a blade (and gib) bend and wreck havoc and there were no broken screws….like Bert said, the Shelix head is incredible, but spendy. Something to think about if you run the planer a lot….....
-- Jeff .... Minnesota, USA
b2rtch
#8 posted 11-12-2013 08:56 PM
Probably pretty difficult to drill out, grade 8. Not impossible but difficult, the best bits to try that are the Cryobit, expensive but very good.
-- Bert
b2rtch
#9 posted 11-12-2013 08:57 PM
$437 to be exact. I am thinking abuot this option for my Ridgid planer
-- Bert
View DocSavage45's profile
DocSavage45
8554 posts in 2841 days
#10 posted 11-13-2013 01:06 AM
Is there a machine shop or good /technically proficient mechanic who rebuilds engines near you? Might have the necessary tools to remove or drill out and re tap the threads.
It’s a good reminder to tune up our tools more often than we do.
-- Cau Haus Designs, Thomas J. Tieffenbacher
View JoeinGa's profile
JoeinGa
7736 posts in 2005 days
#11 posted 11-14-2013 10:42 PM
If Ridgid is gonna fix it under warranty, take it in.
If you’re gonna hafta pay, find a local machine shop and he’ll probably do it cheaper (and WAY faster)
