Let's Talk Router Table Fences
Forum topic by jonah posted 11-12-2013 04:49 PM 2791 views 0 times favorited 18 replies Add to Favorites Watch
View jonah's profile
jonah
1570 posts in 3200 days
11-12-2013 04:49 PM
I picked up a steal-of-a-deal Freud FT3000VCE router and Jessem router lift separately off Craigslist. The lift came with a laminate table top that the previous owner had made which I want to make use of. So I have a nice router and lift/tabletop. What I lack is a fence. I’ve done a little research, and have the following options (among others):
Freud SH-5 from Amazon – $100
Kreg fence from Amazon – $200
Rockler fence from Rockler – $80
Rockler “Pro” fence – $140
The Kreg fence looks nice but $200 is more than I want to spend on this, so that’s out. I checked MLCS but it doesn’t look like they sell fences separately. I like the look of the micro-adjusters on the Freud fence. It doesn’t seem like the Rockler ones have that. The main advantage of the Rockler fences would be the built in t-tracks and that they are a little longer than the Freud one.
What say you, Lumberjocks? Have you used any of those three fences? Which stands out? Any other options I haven’t mentioned for a good price? I’d like to stay in the ~$100 and under range if possible.
18 replies so far
View Rex B's profile
Rex B
320 posts in 2152 days
#1 posted 11-12-2013 04:52 PM
You forgot the cheapest option, build one yourself! Here’s mine, but there are tons of others out there with more features. Customize it however you want!
-- Rex
View chrisstef's profile
chrisstef
17162 posts in 2908 days
#2 posted 11-12-2013 04:58 PM
Ive got this fence on my router table and I really like the micro adjustability of it.
http://www.amazon.com/Freud-SH-5-Professional-Micro-Adjustable-Router/dp/B00005Q7CN
View pintodeluxe's profile
pintodeluxe
5565 posts in 2715 days
#3 posted 11-12-2013 05:01 PM
Bench Dog makes my favorite fence. It is solid aluminum, and heavy duty. It features a split fence with replaceable MDF inserts, jointing feature, and a vac port.
Otherwise, you can buy parts and knobs from Kreg and build one. I used this one for a while until I purchased the Bench Dog.
http://lumberjocks.com/projects/44902
jonah
#4 posted 11-12-2013 05:19 PM
Hadn’t really considered making my own fence. Interesting idea. It probably wouldn’t cost me a whole lot less than some of the cheaper fences I could purchase, but it’d certainly be custom to my needs.
Chrisstef, do you find that the Freud fence you have is too short for any common operations? I liked the look of the micro-adjustability but was a little put off by how short the fence seemed.
View MT_Stringer's profile
MT_Stringer
3152 posts in 3133 days
#5 posted 11-12-2013 05:22 PM
I made my own fence. It has worked to my satisfaction so far. However, your needs may be different than mine.
I enjoy making my own stuff. :-)
Steve Ramsey has a video that might be helpful.
View TeamTurpin's profile
TeamTurpin
85 posts in 1963 days
#6 posted 11-12-2013 05:29 PM
Made my own. It was a fun project.
-- http://www.teamturpin.org/house/shop.htm
chrisstef
#7 posted 11-12-2013 05:30 PM
Jonah – I haven’t found it too short for any operations to date, however I don’t run thousands of bf through it on a yearly basis so YMMV. The good thing about that fence is that you can replace the MDF fence with any length of hardwood you choose. Its held on with 4 screws.
Edit – The fence can also adjust left to right, either extending the length or minimizing the length down to almost zero clearance
jonah
#8 posted 11-12-2013 09:29 PM
My use is very much hobbyist, not production. I’ve never owned a router table before, and while there are certainly quite a few potential operations that I see myself doing with it, I’m certainly not going to be living in front of the router table.
I’m leaning in the direction of the Freud fence with a strong consideration for making my own.
View WhoMe's profile
WhoMe
1564 posts in 3145 days
#9 posted 11-12-2013 09:45 PM
We sell the Kreg, Rockler and Benchdog wether I work. The Kreg is the only one I ever hear complaints about. The version of the Kreg we sell has the dust port offset from where the router bit is positioned and the complaints are that it is terrible for dust collection. Other than that, no other complaints. So if upper dust collection is important, it is somethin to consider.
-- I'm not clumsy.. It's just the floor hates me, the tables and chairs are bullies, the wall gets in the way AAANNNDDD table saws BITE my fingers!!!.. - Mike -
View Cole Tallerman's profile
Cole Tallerman
392 posts in 2087 days
#10 posted 11-12-2013 09:52 PM
You would be surprised how much the router table is used for hobby work. I make lots of cutting boards and I find that half of my shop time is spent in front of the router table.
View ColonelTravis's profile
ColonelTravis
1744 posts in 1796 days
#11 posted 11-12-2013 10:08 PM
Would you rather say “look at my fence!” or “look at this end table I made!”?
Make a fence, use the saved money for your projects.
jonah
#12 posted 11-13-2013 01:41 PM
See thats sort of a vote for buying one, Travis. I’d rather spend workshop time building something that’s not for the shop, as much as I do like shop projects. Two ways to look at it, I guess.
Still not sure where I’m going with this in terms of buying vs. making a fence, but I do appreciate all the perspectives.
View redSLED's profile
redSLED
790 posts in 1794 days
#13 posted 11-13-2013 02:36 PM
I’m making my own router fence and table in the spring to do light production work – for edge routing 95% of the time.
For edge routing 6-8’ boards – can any of you guys/gals chime in with your opinion of the ideal router fence length, if such a thing exists?
View Tedstor's profile
Tedstor
1643 posts in 2534 days
#14 posted 11-13-2013 02:44 PM
+1
View moke's profile
moke
1102 posts in 2678 days
#15 posted 11-13-2013 03:49 PM
Ordinarily, I’m with you and Tedstor, I work two jobs and shop time is precious, but not this time. I built my own fence…a couple of times in fact. I could just not find what I wanted. The first time I used an extrusion like TeamTurpin—-(please don’t take offense)...it was great…looked pretty…has no issues with being flat…was not going to warp…..until I want to “edge route” a tall piece…it was to short. I also wanted to swing some rased panel bits…the opening was too small…so I built a fence that was tall like MT Stringer with the t track for hold downs but I made it so it could split and adjust that split to accomidate really big bits.
And as long as I’m offending all my friends…a friend of mine bought a Kreg table and fence. I love kreg…they are in Iowa and so am I, their customer service is awesome, and their products are ordinarliy great, but that router table fence are wierd. They tried to be innovative and I think they missed…...
Just my .02
Mike
-- Mike
