Deep 410mm (16") concealed floating shelf support
Forum topic by Lennardo posted 11-12-2013 03:52 PM 2075 views 0 times favorited 4 replies Add to Favorites Watch
View Lennardo's profile
Lennardo
2 posts in 1891 days
11-12-2013 03:52 PM
Topic tags/keywords: shelf shelves concealed support supports question help
Hello
I wonder if you can help. I have some 25mm h x 410mm d x 1250mm w shelves to hang. They must be hung using concealed shelf supports. If only they were just 300mm (12”) deep that would be easy – they’re all here:
http://www.hafele.co.uk/shop/c/cabinet-fittings/concealed-shelf-supports/5956
But these shelves are deeper by 110mm. Has anyone used a product or solution to hang a similar shelf in a ‘floating’ manner
Many thanks in advance for your help
View joeyinsouthaustin's profile
joeyinsouthaustin
1294 posts in 2307 days
#1 posted 11-12-2013 04:10 PM
I would not recommend going past the hafele recommendations. I usually make custom steel brackets to hang selves that large, and it involves cutting back into the plaster or sheet rock, and installing the supports deep into framing, and then repairing.
-- Who is John Galt?
404 - Not Found
2544 posts in 3203 days
#2 posted 11-12-2013 04:15 PM
Are these going on a masonry wall?
Lennardo
#3 posted 11-12-2013 06:14 PM
Yes – it is the dividing wall so very sturdy
Thank you both
404 - Not Found
#4 posted 11-12-2013 07:09 PM
I have seen it done using lengths of threaded rod glued into the wall, but with the depth you have, a steel tube might be better. The lighter you can make those shelves the better, ie. torsion box (hollow) construction. If you are going the rod or tube route, bore oversize in the wall and fill it with a building adhesive like Tec7 or Gripfill, insert the rod or tube and support them while the adhesive is drying. Best make a template for hole location for wall and back of shelf. If you use a threaded rod go at least 12mm.
