Wedge shaped bread board end
Forum topic by cdyrssen posted 11-11-2013 04:06 PM 2139 views 0 times favorited 11 replies Add to Favorites Watch
View cdyrssen's profile
cdyrssen
5 posts in 1895 days
11-11-2013 04:06 PM
Topic tags/keywords: bread board design desk wood movement inlay
Hello everyone. My name is Christoffer Dyrssen and this is my first post on the forum. I am fairly new to woodworking but have been doing a bunch of research on the topic and have recently decided to take on the project of making myself a desk. I just had a question about this breadboard end that came up during a google search. It has the breadboard wedged into the top panel with a shallow angle. I know that this will be problematic due to wood movement. My question comes in here. I was wondering if I would still have problems if, instead of making the entire bread board end wedged between the top panel I made like a half lap kind of overlay from the bread board and created a groove for it to rest inside of the actual top. Maybe a better way to describe my idea would be to make a normal bread board, but have a thin overhang shaped like a wedge on the show side that is inlayed into the top. I hope that I am describing this alright. I can come up with a drawing if you have problems understanding what I am trying to explain. Just was wondering if this would solve the problem or would it still be a problem.
11 replies so far
View LakeLover's profile
LakeLover
283 posts in 2175 days
#1 posted 11-11-2013 04:54 PM
I am a bit confused a cross section drawing would help.
That would be a nice looking top if you can pull it off.
Have you considered veneer over ply and not worry about wood movement ?
cdyrssen
#2 posted 11-11-2013 05:07 PM
To get the thickness I wanted for the top I ended up having to use 5/4 solid wood, so unfortunately that was not an ideal method. I will try and get a drawing up to give you a visual description of my thoughts.
View pintodeluxe's profile
pintodeluxe
5815 posts in 3048 days
#3 posted 11-11-2013 05:38 PM
Even standard breadboard ends are tricky and problematic. I would save yourself the heartache and start with a regular breadboard. After the joinery is cut, you could taper the outside edge of the breadboard end for a similar look.
cdyrssen
#4 posted 11-11-2013 05:44 PM
I had thought of that as well. That is kind of my plan b right now if it is going to be too impractical to make this design.
pintodeluxe
#5 posted 11-11-2013 05:47 PM
The problem is a large table will move 3/8” – 1/2” across its width seasonally. So the wood will create a gap at the outer breadboard joint. Whatever means you use to attach the end to the table will be stressed and could fail.
Best of luck with whatever method you choose.
pintodeluxe
#6 posted 11-11-2013 07:22 PM
It looks pretty striking with an external taper.
Another option is to reverse the external taper, so the chevron points to the center of the table. I don’t care for the look of this one as much.
View BJODay's profile
BJODay
527 posts in 2178 days
#7 posted 11-11-2013 08:33 PM
An external “out” taper looks nice. I think it would be easier to create.
The internal, “chevron” looks difficult. You could make the chevron cut using a pattern and a pattern bit on a router.
BJ
View Texcaster's profile
Texcaster
1286 posts in 1909 days
#8 posted 11-11-2013 08:48 PM
Chris,
I like to see people challenge the old mouse trap. Quarter sawn timber will help and keep it small.
The mitered bb in the pix….550mm or 21 1/2 in. It’s about 10 years old. Bunya Pine. If I get a lot of
movement I’m calling it antique.
-- Mama calls me Texcaster but my real name is Mr. Earl.
cdyrssen
#9 posted 11-11-2013 09:50 PM
Here is a drawing of what I was thinking. My drafting skills are not the greatest so I hope it is clear enough to get the idea. None of it is really drawn to scale. I was planning on using oversized mortises in the bread board with the middle tenon glued in. Would this need any othe sort of reinforcement? Would I need to dowel the mortises and tenons together?
Just a little more information on the project itself. It’s flat sawn poplar and is about 24 inches wide. I live in Midland, Texas, and it’s fairly dry here. I’m not sure what the average relative humidity change is though. Would that information be found at the weather channel website?
pintodeluxe
#10 posted 11-11-2013 10:02 PM
That would work. Just expect some gaps at the joint seasonally. Not that big of a problem for a desk. On dining tables food gets in the cracks, but on a desk it should be okay.
I usually leave my breadboard ends wider than the table. If the tabletop shrinks narrower than the breadboard end, it looks odd.
cdyrssen
#11 posted 11-14-2013 06:08 AM
Well I think I am going to go ahead and give this a try and will post pictures of the finished results! Thanks everyone for the input!
