How to cut a perfect elongated hole?
Forum topic by Blackie_ posted 11-10-2013 02:50 PM 5401 views 0 times favorited 14 replies Add to Favorites Watch
View Blackie_'s profile
Blackie_
4846 posts in 2417 days
11-10-2013 02:50 PM
I need help on how to go about cutting a perfect elongated hole in a 5/8” thick piece without tear out on the back side, I need it 1 3/8” long by 1/2” wide, rounded on each end.
Thanks
-- Randy - If I'm not on LJ's then I'm making Saw Dust. Please feel free to visit my store location at http://www.facebook.com/randy.blackstock.custom.wood.designs
14 replies so far
View RockyTopScott's profile
RockyTopScott
1186 posts in 3383 days
#1 posted 11-10-2013 02:53 PM
Drill the ends, then drill out the middle a bit and chisel out the middle to finish.
-- “When you want to help people, you tell them the truth. When you want to help yourself, you tell them what they want to hear.” ― Thomas Sowell
View JustJoe's profile
JustJoe
1554 posts in 1943 days
#2 posted 11-10-2013 02:58 PM
Do you mean you need to hollow out an oval shape in a 5/8” thick piece of wood?
You can tape or clamp a thin piece of wood on the back to prevent blowout.
Then just get a decent 1/2” spiral up-cutting bit in the router, plunge in, route over, lift up, done.
-- This Ad Space For Sale! Your Ad Here! Reach a targeted audience! Affordable Rates, easy financing! Contact an ad represenative today at JustJoe's Advertising Consortium.
Blackie_
#3 posted 11-10-2013 02:58 PM
Yea Rocky, that is what I was thinking, using a fostner bit on the ends but wasn’t sure for the center, I had a scroll saw in mind as well.
I’ve been asked several times now from customers about phone docking in my valet boxes, I need to start including this feature on the back wall of my boxes.
Blackie_
#4 posted 11-10-2013 03:00 PM
ah ok Joe, I could use the router table with stop blocks?
What if I used a fostner to drill the ends then the middle with the 1/2” up spiral bit don’t think I would need stop block then.
RockyTopScott
#5 posted 11-10-2013 03:01 PM
If you use a knife to mark the oblong Blackie, you should have a guide for the chisel to start. I learned the hard way.
16272 posts in 4123 days
#6 posted 11-10-2013 03:14 PM
If you have a drill press, just use a forstner bit, attach a backer board to the workpiece, and set up a fence. Make your two end cuts first, then slide along the fence, making multiple cuts to hollow out the middle.
View GOOD LUCK TO ALL's profile
GOOD LUCK TO ALL
418 posts in 1632 days
#7 posted 11-10-2013 03:20 PM
I would just use the router table and lower the work pc over the bit.
Blackie_
#8 posted 11-10-2013 03:23 PM
Ok I just did it on a scrap piece, I first drew out the cut path using the drill press and 1/2” forstner bit I punched out the starting hole I then took it over to the router table lined the fence up placed the work piece down over the 1/2” up spiral bit and it went as smooth as butter clean and quick.
Charlie, I like your method also.
Thanks everyone I just needed that simple push to get me started :)
View DocSavage45's profile
DocSavage45
8453 posts in 2747 days
#9 posted 11-10-2013 04:38 PM
Randy,
using a 1/2 inch non brad point smooth tip drill bit can also reduce tear out. Hardness or brittleness of the wood is also an issue.
What I learned from Charles Neal is setting the start and stop blocks on your router table and use a practice piece of same material. Slowly, with piece against the fence, lower the material onto the router bit, then go from stop to stop. He makes it look easy! LOL! Sounds as if you already have a solution.
good luck.
-- Cau Haus Designs, Thomas J. Tieffenbacher
Blackie_
#10 posted 11-10-2013 05:00 PM
Thanks Thomas, yea I’ve done it many times when cutting kerfs for the bottom in my box joint boxes, only I don’t go all the way through :)
116902 posts in 3482 days
#11 posted 11-10-2013 09:24 PM
View distrbd's profile
distrbd
2252 posts in 2351 days
#12 posted 11-10-2013 09:31 PM
@a1jim,Need to get a few of those bits now,does it ever end?lol.
-- Ken from Ontario, Canada
View Tooch's profile
Tooch
1699 posts in 1781 days
#13 posted 11-11-2013 10:37 AM
put a backer board to prevent blowout, then spindle sander to get it perfectly smooth.
If you’re going to be including this feature a lot, it might be a good idea to create a template you can use with a Flush cut router bit, then you can just mount the template on your work piece and be done very quickly. Rockler sells the bits fairly cheap:
http://www.rockler.com/pattern-flush-trim-router-bit
they also have them in 1/4 ” shanks and with the bearing on top or bottom, depending on your preference.
-- "Well, the world needs ditch-diggers too..." - Judge Smails
Tooch
#14 posted 11-11-2013 10:41 AM
wait, nevermind… I just re-read your post and finally got what you’re trying to do. I don’t think a pattern bit is needed, just a couple stop blocks on the table would suffice.
