Ideas for reusing bandsaw blades?
Forum topic by Sinister posted 358 days ago 735 views 1 time favorited 21 replies Add to Favorites Watch
View Sinister's profile
Sinister
18 posts in 368 days
358 days ago
Don’t ask me how, but I managed to put a kink in a relatively new bandsaw blade, rendering it useless. It’s a ¾” 3 TPI timber wolf. It’s still sharp and I’d hate to throw it out. Has anyone seen any useful tools or jigs that I could use it for?
-- Patrick, Iowa City
View Kindlingmaker's profile
Kindlingmaker
1476 posts in 424 days
358 days ago
I use old blades to make blades for hacksaws and others. Shear to length and punch holes where needed. I know that a 3 TPI hacksaw looks strange but its really handy. The 3 TPI in a bow saw is great for trimming trees. Tage Frig (sp) used pieces on them to clean out his dovetails by grinding off the teeth and sharpening then using a hammer to tap his blade knife into the wood. One of his videos shows this very well.
View Tim from Iowa City's profile
Tim from Iowa City
186 posts in 498 days
358 days ago
Might be able to use some of the blade for tearing off sheets of sandpaper. I have a palm sander that takes squares of sandpaper. I usually have 8.5×11 sheets of sandpaper that I fold and cut to size. It can be tedious and generally slows me down. Might be overkill for your blade. This idea might be better suited for an old hacksaw blade or something with a few more teeth. All that being said, this might stir up or trigger an idea for you. Tim
-- Tim from Iowa City, IA
View Bill White's profile
Bill White
111 posts in 858 days
358 days ago
I keep some pcs. of band saw blades (about 12” long and taped on both ends) by my buffing station to “fluff up” the buffing wheels prior to adding more buffing compound.
Bill
View Blake's profile
Blake
2763 posts in 772 days
358 days ago
It could actually be cut and re-soldered at a saw shop. It probably wouldn’t cost too much. You don’t have to scrap it. They even make blade soldering kits so you could do it yourself.
This one is only $35 at WOODCRAFT:
View Loren's profile
347 posts in 546 days
358 days ago
You can make a bowsaw and use it for hand-ripping. 3 TPI
is pretty coarse for cutting joints though.
You can also make yourself a walking-beam saw. There
are directions on it in some old FWW issue.
Blades are hard steel so they work as scrapers. You might
cut it into 4” lengths and make a holder.
-- Would you like to recession-proof your present business using the internet? - my revealing 9-page free report gives you the straight facts: http://copymatch.com/rec/cap.html
Sinister
358 days ago
These are some good ideas. I hadn’t considered trying to re-solder it. That kit would be a worthwhile investment if it worked.
View HokieMojo's profile
HokieMojo
1142 posts in 626 days
358 days ago
I did the same thing. I should have thrown the blade out months ago, bu felt guilty for some reason (even though it was unusable). Now that I can do something with it, I’m glad I didn’t . Thanks for the post and all the replies!
View fred4999's profile
fred4999
77 posts in 382 days
358 days ago
Hmmmm, ideas abound here, thanks. I have a bunch of old Wood-Mizer sawmill band blades. You are all welcome to them if you come and get them and post a picture of what you make with them – I live in west central GA. Regards
-- Fred, Georgia
View dirtclod's profile
dirtclod
165 posts in 758 days
358 days ago
This topic comes up from time to time on the sawmilling forums. I don’t know how wide your blade is compared to the smallest 1-1/4” used on bandsaw mills. But steak knives are often mentioned as possible reuses . I’ve got a few broken ones hanging in a tree that I’d give away to a new home.
-- Wonderful new things are coming! - God
View bob101's profile
bob101
46 posts in 348 days
333 days ago
you can use them to make knives for cutting bread as well
-- rob, ont,canada
dirtclod
332 days ago
Cut off all but one backward-facing tooth, put a handle on it, and you have:
1- grout/caulk remover
2- carpet/ linoleum cutter
I suppose you could also make some pretty good scrapers out of them.
View RichardB's profile
RichardB
69 posts in 387 days
332 days ago
Cut it into multiple lengths, attach them to a handle, and you can create “distressed wood” like nobody’s business!
Mount it teeth up to keep birds from perching somewhere.
View GaryK's profile
GaryK
9537 posts in 886 days
332 days ago
Bowsaw.
View Waldschrat's profile
Waldschrat
340 posts in 334 days
332 days ago
they make great intarsian and marquetry cutting tools as well as doing wood carving (various self made knives for small detials and such)
-- Nicholas, Journeyman Cabinetmaker, Partenkirchen, Germany
Douglas Bordner
3427 posts in 962 days
331 days ago
Custom ground profile scrapers.
View sidestepmcgee's profile
sidestepmcgee
136 posts in 623 days
331 days ago
a 2ft scarp piece is handy when my buddys wood mizer gets jammed up ,we use it to free the sawdust out behind the blade so we can pull the blade back out.Like the scrapers idea!thanks
-- eric post, tallahassee FL
View socalwood's profile
socalwood
968 posts in 502 days
331 days ago
I’ve seen them used in a tool to score the cambium layer on fruit trees for increased production . It works well and is called girdling . A smart person reading this should start marketing these tools .
View DannyBoy's profile
DannyBoy
448 posts in 763 days
331 days ago
How about really manly bracelets?
-- He said wood...http://hickbyassociation.blogspot.com/
dirtclod
140 days ago
Modify this idea using bandsaw blades instead of hacksaw blades: http://www.primitiveways.com/two_bladed_pocket_knife.html
View Broda's profile
Broda
235 posts in 417 days
140 days ago
you could also make your own thin parting tools out of them.
sorta like the one in this video, but with a bansaw blade instead.
http://www.youtube.com/watch?v=8Joo-cBzsjQ&feature=channel_page
I have made one of these and i use it alot, they work well.
-- BRODY. NSW AUSTRALIA -arguments with turnings are rarely productive-
View SnowyRiver's profile
SnowyRiver
3467 posts in 378 days
139 days ago
They would work great for flossing your teeth :-)
-- Wayne - Plymouth MN
