What finish for bathroom vanity
Forum topic by ToddJB posted 11-09-2013 08:36 PM 1315 views 0 times favorited 13 replies Add to Favorites Watch
View ToddJB's profile
ToddJB
7984 posts in 2155 days
11-09-2013 08:36 PM
All,
I’m converting a dresser into our bathroom vanity. It currently has some sort of finish on it, but I want to put something very durable on it, as it will be getting splashed with water.
I would like to keep the low luster and rustic look. I’m not a fan of shiny.
I’m looking for some specific suggestions that I can pick up a Lowes or HD
Below are some pics
-- I came - I sawed - I over-built
13 replies so far
View LukieB's profile
LukieB
966 posts in 2355 days
#1 posted 11-09-2013 09:08 PM
I’ve used this stuff before for a somewhat similar project.
A old blanket chest that they didn’t want to be shiny, but wanted to be protected from the kind of water stains that they wanted off of there from cups without a coaster and such. It had served some duty as a coffee table at one point…
-- Lucas, "Someday woodworks will be my real job, until then, there's this http://www.melbrownfarmsupply.com"
View pintodeluxe's profile
pintodeluxe
5705 posts in 2838 days
#2 posted 11-09-2013 09:42 PM
It really depends what is on the piece now. I like lacquer best, in the satin finish. It holds up well in bathroom vanity applications. If there is wax on the piece, any film finish like lacquer or poly will give you trouble.
You could try some in an inconspicuous area to see what the results are. If it dries without fish eyes, then you should be okay.
Shellac is also an option.
View verdesardog's profile
verdesardog
161 posts in 2636 days
#3 posted 11-09-2013 10:28 PM
Looks like it has been stripped or sanded? I woul use water based polyurethane. Several coats.
-- .. heyoka ..
View Clint Searl's profile
Clint Searl
1533 posts in 2386 days
#4 posted 11-09-2013 10:49 PM
Waterborne poly floor finish.
ToddJB
#5 posted 11-10-2013 02:03 AM
Thanks for the suggestions, guys!
It has not been stripped or sanded, it was just finished with something while still pretty rough. You can see in the second pic that there is a color difference on the side where it goes inside of the cabinet where they stopped with the finish.
View Grandpa's profile
Grandpa
3259 posts in 2700 days
#6 posted 11-10-2013 03:19 AM
Clint, wouldn’t water harm your finish? I just inspected a 6 year old home that has a LOT of the cabinet finish damaged and worn. It has what looked like drops in the cabinet shelves. These were spot about the size of dimes that looked like water had been dropped on them and the clear finish had come off resulting in lighter places now that the stain is exposed. I am curious about some thoughts on water based poly for cabinets where water damage might occur.
Clint Searl
#7 posted 11-10-2013 05:54 PM
Grandpa, short of a conversion varnish or other catalyzed finish, a poly floor finish is about as tough as it gets. I like Bona Mega, an oxygen cross-linking poly.
BTW, on this project, I would strip any old finish completely before doing anything else.
View Keith Glass's profile
Keith Glass
8 posts in 1899 days
#8 posted 11-15-2013 11:40 AM
Cross-linking -poly is the best option for the above shown bathroom vanities.
The two things for this
1 : Highly durable
2 : Highly moisture resistant.
http://www.thertastore.com
-- Keith Glass
View bigblockyeti's profile (online now)
bigblockyeti
5139 posts in 1745 days
#9 posted 11-15-2013 01:41 PM
I built a mirror frame to go in the bath and used a high gloss lacquer, while that glossy look isn’t what you’re looking for, you could get it in satin and burnish it a little if your looking for even less of a reflective finish. You’d be able to slowly achieve just the sheen your looking for with this method.
Grandpa
#10 posted 11-15-2013 05:05 PM
Well, I was reading Clint Searl’s answer above and he says WATER BORNE poly. Is that not water based?? I believe water will cause this to release. Thanks
Keith Glass
#11 posted 11-19-2013 06:17 AM
You are absolutely right Grandpa.
-- Keith Glass
View Henry6's profile
Henry6
36 posts in 2052 days
#12 posted 11-19-2013 11:29 AM
That is looking good enough,But its wood so make sure that you have coated it already with some stain or there are chances that the wood might come in contact with the water.
View KingoftheForest's profile
KingoftheForest
1 post in 1668 days
#13 posted 11-26-2013 12:52 AM
I build vanities and have found the best top coat is the two part epoxy made by Glaze Coat. Its made for water areas and is also used on bar tops. You pour it on and its leveled using a glue spreader.The finish is gloss but can be dulled up with fine steel wool. It works great for the ruff unsanded serfaces.
