Workshop Equipment Assistance: Repulsion Induction Motor
Forum topic by Lambertwoodworks posted 11-09-2013 03:54 AM 2624 views 0 times favorited 12 replies Add to Favorites Watch
View Lambertwoodworks's profile
Lambertwoodworks
6 posts in 1700 days
11-09-2013 03:54 AM
Topic tags/keywords: equipment motor make your own tools make your own equipment oil lubricant service maintenance
I have an induction motor that I’d like to service, but I do not know the type/weight oil to use in this motor. The motor is an older Delco motor, currently set up for use as a grinder. A pic of the motor from the net…
I’d also like to know if there are better uses for this motor. Since I have a few extra motors, I could make some changes and use it as another piece of equipment. It is a low HP motor, but I’m sure there are better uses for a motor of this quality. This thing is super smooth on start-up and nearly silent while running. I’m sure there are a few LJs who have knowledge of these motors.
The specs for the motor are:
Model Number: 4125
Amps: 3.1 – 1.55
HP: 1/6
RPM: 1730
-- LW
12 replies so far
View Bill White's profile
Bill White
4948 posts in 3984 days
#1 posted 11-09-2013 03:41 PM
Just plain old 30w oil will work just fine.
I have a GE “watermelon” motor being used as a buffer. No tellin’ how old this little feller is, but it runs like a top.
Oil it about twice a year, keep it blown out and wiped off.
Yours, being branded as Kelvinator, is probably a washing machine motor.
Most likely its an open motor, and grinding swarf will get inside and create some problems.
Bill
-- bill@magraphics.us
View MrRon's profile
MrRon
4793 posts in 3267 days
#2 posted 11-09-2013 05:34 PM
That would be an ideal size for a fan. Repulsion/induction motors are workhorses. I had some that were in use for over 50 years and never gave any problems, as long as you oiled them regularily.
View MedicKen's profile
MedicKen
1615 posts in 3486 days
#3 posted 11-10-2013 01:50 PM
I have an Delco motor of about the same vintage and have been using 30wt. Mine is 1/2hp and has been oiled with 30wt for probably 60 yrs.
View Jim Finn's profile
Jim Finn
2657 posts in 2945 days
#4 posted 11-10-2013 01:57 PM
I have serviced many of these old motors on furnaces and I always used a 30W non detergent oil. Never use “Three in one oil” or any other oil with wax in it.
-- Website is No PHD just a DD214 and a GED https://craftingcouple.com/
View cpd011's profile
cpd011
90 posts in 3261 days
#5 posted 11-10-2013 02:10 PM
Now that I read this I wonder…I have a 1947 Unisaw with the original motor which I believe is a repulsion/induction. Does it need to be oiled?
View dhazelton's profile
dhazelton
2771 posts in 2320 days
#6 posted 11-10-2013 02:17 PM
Are you folks taking about bronze sleeves instead of bearings? Why can’t I use 3 -in -1? I just put a Dunlap into service as a buffer and I oiled it with 3-in-1…..
Bill White
#7 posted 11-10-2013 03:55 PM
3-in1 just won’t have the film strength on a bronze bearing that 30wt will.
Shear the oil film-no lube for the bearing.
Bill
View Bluepine38's profile
Bluepine38
3379 posts in 3109 days
#8 posted 11-10-2013 10:00 PM
cpd011, that 1947 unisaw should have sealed ball bearings in it, does not require oiling, it is also called a
bullet motor and you can find out all about it on the Vintage Machinery site.
Lambertwoodworks
#9 posted 11-11-2013 01:11 AM
I had a feeling that 30w oil was the answer. I appreciate the tip for the 3-in-1 oil, as well. Never knew that and it’s the most used oil in my shop. I’m thinking about using this motor for a ceiling dust collector. Any thought on this? Thanks fellas.
-- LW
View Grandpa's profile
Grandpa
3259 posts in 2699 days
#10 posted 11-11-2013 03:18 AM
+1 for the non-detergent oil. In fact I believe it should be 10W non-detergent. Do some reading on this and that is what you will probably find. I have used everything but that is the proper thing to use.
dhazelton
#11 posted 11-11-2013 02:25 PM
I have a 1940s Craftsman 6×48” belt/disk sander and an old arbor set up as a buffer with oil cups and bronze sleeves – use the motor oil there as well I suspect?
View bigblockyeti's profile
bigblockyeti
5137 posts in 1744 days
#12 posted 11-11-2013 03:52 PM
I have a delta drill press with one on it, but it has ball bearings which do not require periodic oiling. Some of these motors can be valuable to some people. If nothing else, whatever you end up using it for, keep it visible just for the coolness factor!
