Having Bandsaw Problems
Forum topic by kingswoodworking posted 11-08-2013 04:20 PM 921 views 0 times favorited 5 replies Add to Favorites Watch
View kingswoodworking's profile
kingswoodworking
2 posts in 1538 days
11-08-2013 04:20 PM
Topic tags/keywords: bandsaw
Hi,
I am new to woodworking so I do not have a lot of knowledge yet. I have just purchased a Ryobi 9” Band saw mainly because it was cheap and I am on a strict starter budget. It came with a 1/4” blade on it that worked pretty well on a few band saw boxes I tried but I heard you could get tighter turns with an 1/8” blade so I went out and bought a decent one not a real expensive one. I followed the changing the blade instructions and also watched a few videos on how to change one on YouTube before I changed it. I got it to track in the middle of the wheel like the instructions said to do and put the guides where they are recommended to be but every time I try and cut through something the blade pushes back behind the two side guides and to the side of the bearing wheel. I tried adjusting the tension but it didn’t seem to work. I don’t know if the blade is bad or what. I have limited knowledge. Any help would be appreciated.
5 replies so far
View Bill White's profile
Bill White
4823 posts in 3837 days
#1 posted 11-08-2013 04:28 PM
1/8” blades cannot ride between the side rollers/guides. They must be set to work with the rear guide, and properly tensioned to work without the support of the side guides.
The exception to this (you knew there had to be one) is when you are using soft side guides such as a wood or phenolic block. These guides can be set to cover the sides of the blade (think pinching the blade between thumb and forefinger).
Crank up the tension little by little while you run some practice stock through the saw.
Good luck.
Bill
-- bill@magraphics.us
View mahdee's profile
mahdee
3831 posts in 1644 days
#2 posted 11-08-2013 04:29 PM
Could it be that it is put on backwards? The teeth should point down. Otherwise, it is normal for the bearing wheel to turn.
-- earthartandfoods.com
View Surfside's profile
Surfside
3389 posts in 2050 days
#3 posted 11-08-2013 10:02 PM
Keep turning the top wheel by hand; adjust the tilt until the blade tracks in the middle.Turn it on and make sure if it stays there . If you’re satisfied with the tracking, set up your blade guides. You can use a paper bill to set accurately the distance of the blade and the guides. If the blade is damaged, it won’t track well ; most likely jump off while cutting and you better start with new blade and set up everything right from the start.
-- "someone has to be wounded for others to be saved, someone has to sacrifice for others to feel happiness, someone has to die so others could live"
View distrbd's profile
distrbd
2252 posts in 2323 days
#4 posted 11-08-2013 10:49 PM
Did you also set the thrust bearings distance correctly?they are the one that prevent the blade from moving too far back,I think you should start from scratch to set up your bandsaw just like surfside said above,loosen the tension on the blade ,make sure the upper wheel is not tilted,move the thrust bearings/guide blocks back,then increase the blade tension. Turn(by hand) the upper wheel counter clockwise while adjusting the tilt so the blade tracks in center of the upper wheel,then setup the bearings/guide blocks.
-- Ken from Ontario, Canada
View gfadvm's profile
gfadvm
14940 posts in 2567 days
#5 posted 11-09-2013 03:06 AM
I agree with Ken. The thrust bearing should be adjusted to keep the bade from getting pushed back during a cut. Unless this little Ryobi is designed differently from all the bandsaws I have used.
