My Edge Jointing method--tell me what's wrong with it
« back to Joinery forum
Forum topic by CharlesA posted 11-07-2013 08:15 PM 1450 views 0 times favorited 16 replies Add to Favorites Watch
View CharlesA's profile
CharlesA
3319 posts in 1794 days
11-07-2013 08:15 PM
Topic tags/keywords: question jointer plane tablesaw joining
I don’t have a powered jointer, for space and $ reasons, so I’ve been using a jointer plane to joint the edges of lumber. But I’ve found it quite time consuming to get a perfect edge. So this is what I have been doint:
1) Use the plane to get it 90-95% flat—no curves.
2) Rip the other edge using the planed edge against the fence.
3) Rip the planed edge using the newly ripped edge against the fence.
This seems to work well. Thoughts?
Charles
16 replies so far
View Lee Barker's profile
Lee Barker
2170 posts in 2846 days
#1 posted 11-07-2013 08:25 PM
Sounds real workable to me, Charles. You’re making the most of the tools that you have and your own ingenuity. If that isn’t a definition of what we’re all doing, then I’ll buy you a gallon of glue.
Kindly,
View okwoodshop's profile
okwoodshop
448 posts in 3171 days
#2 posted 11-07-2013 08:29 PM
I started out the same way, you use what you have but when I finally saved up for a jointer it sure saved a lot of time.
View Loren's profile
10381 posts in 3644 days
#3 posted 11-07-2013 08:41 PM
I’ve ripped plenty of glue joints that way, more or less. The joints
are tighter if they’re run on a jointer usually, but if you’re
careful with ripping technique acceptable joints can
often be got right off the saw. They tend to be a bit
more visible after glue-up, but in the greater scheme of
things it’s a nitpick for all but the finest work.
View Dallas's profile
Dallas
3599 posts in 2483 days
#4 posted 11-07-2013 08:44 PM
I have no jointer either. Wish I did.
If the stock is under 6” I clamp it together and run it through the planer.
If it’s larger than 6” I use the router table.
I am not against hand tools. There are many times they are required and everyone needs those skills.
Power tools were not invented to be better than hand tools but to allow wood workers to enjoy the fruits of their labor.
It ain’t no fun toiling day after day making a single profile in a production shop. Imagine trying to do it with hand tools.
CharlesA
#5 posted 11-07-2013 09:07 PM
I don’t have a problem using the jointer plane, it’s part of my process of getting to know/become proficient with planes that is really improving my work. And with my method, it sometimes only takes a couple of minutes with the plane. If the board is more out of line, then it is more work, but I did three boards today that couldn’t have taken more than 5 minutes between them. What I don’t have the patience/skill for is final jointing with the plane.
View lateralus819's profile
lateralus819
2241 posts in 1885 days
#6 posted 11-07-2013 09:31 PM
Maybe try building a fence for your jointer?
lateralus819
#7 posted 11-07-2013 09:31 PM
Maybe try building a fence for your jointer? Also watch this video. http://www.youtube.com/watch?v=TJfD0-fFAzI
It helped me tremendously.
View ADHDan's profile
ADHDan
800 posts in 2104 days
#8 posted 11-07-2013 09:34 PM
I have no jointer and I do all my edge jointing with a table saw hold-down jig that rides the miter slot. The jig is annoyingly large for my small shop, but once I go through the trouble of getting it off the wall it does a good job straightening one edge to use a reference to rip the other. I don’t have a proper workbench for using a jointer plane, and to my chagrin I’ll admit I also don’t have the patience or desire to use hand planes – as much as that goes against the grain of this board (all puns intended).
That said, I also don’t tend to work with large pieces of lumber in my 11×17 shop, so a 4’ straightline rip jig tends to suffice for my needs. If I had to joint anything really long, I’d probably do it with a router, a long straightedge, and a bearing-guided straight bit.
-- Dan in Minneapolis, woodworking since 11/11.
View Tedstor's profile
Tedstor
1643 posts in 2629 days
#9 posted 11-07-2013 09:36 PM
If it works well…..it works well. Woodworking is a results-driven activity.
I just sold my jointer. I wasn’t using it enough, it was taking up space, and in my damp garage….it was rusting away.
I just use a metal straightedge and a flush cut router bit to joint edges. I rarely work with boards over 3-4ft long.
View Monte Pittman's profile
Monte Pittman
29224 posts in 2334 days
#10 posted 11-07-2013 09:44 PM
Not as good, but part of that is how much effort you put in to it. Woodworkers in the old days didn’t have joiners and still did an awesome job.
CharlesA
#11 posted 11-07-2013 09:49 PM
I guess what I’m really asking is this: It appears to me that my method gives me two square parallel edges with the minimum of effort given what I have to work with. Can you think of a reason to work harder with the jointer plane to get that edge perfect before hitting the table saw?
BTW, I love how in plane use videos they always choose a really easy to plane wood. Right now I’m working with cedar for a cedar chest, and if someone can get a perfect edge planing with one hand, then they’re really gifted. Between the knots and the gnarly grain, I can’t get it too work.
ADHDan
#12 posted 11-07-2013 09:53 PM
+1 tedstor.
Results are results; if you get glue-line edges with your method, what value would harder work add? The nice thing about edge jointing is that you can tell whether it worked immediately; if the edges align you succeeded, if they do not you didn’t.
I too am making a cedar chest right now, using my TS jig to rip the edges. It works well and my shop smells pretty good but man, that’s a lot of cedar dust.
View paratrooper34's profile
paratrooper34
915 posts in 2948 days
#13 posted 11-07-2013 09:57 PM
Charles, are you saying you have only one hand? Do you need to know a process for jointing with just one hand?
What is the problem you are having with the edges? Is it that you are having a hard time getting the edge flat along the length or getting the edge to be square with the faces?
-- Mike
View peekasan's profile
peekasan
21 posts in 1701 days
#14 posted 11-07-2013 10:41 PM
OOhhhh that sounds like a ton of work! I would clamp the board to a sled and straightline rip one side if I didn’t have a jointer. You can make a sled that rides in the tablesaw track. A couple of Rockler t-tracks and clamps and it will straighten an edge in one pass. It is basically a large scale tapering jig.
I have a router with offset fence, but honestly I never use it for jointing. I got a used 6” jointer early on, and upgraded to an 8” when the smaller one no longer fit my needs.
Try a TS sled!
View sgmdwk's profile
sgmdwk
308 posts in 1869 days
#15 posted 11-07-2013 11:07 PM
I have used a table saw for years to prep edges for panel glue-ups. Recently I have been using a Stanley No. 6 Fore Plane. I clamp the board to be jointed flat on my bench, with a spacer board underneath. I then lay my plane on its side and plane the board true. It is a crutch because I lack the skill to plane a true 90 degree edge on a board mounted in my vise, but it works great. I have not planed any cedar but have been quite successful on pine, hard maple and oak. I am getting near invisible glue lines with this technique.
-- Dave K.
