A question for cutting board makers
Forum topic by Blackie_ posted 11-07-2013 01:19 PM 1796 views 0 times favorited 23 replies Add to Favorites Watch
View Blackie_'s profile
Blackie_
4846 posts in 2421 days
11-07-2013 01:19 PM
I have a somewhat simple question in regards to finishing on a cutting board, is it necessary to use beeswax if using mineral oil? Also what makes the difference between a serving board and a cutting board?
Thanks
-- Randy - If I'm not on LJ's then I'm making Saw Dust. Please feel free to visit my store location at http://www.facebook.com/randy.blackstock.custom.wood.designs
23 replies so far
View Monte Pittman's profile
Monte Pittman
28214 posts in 2246 days
#1 posted 11-07-2013 01:20 PM
I just use mineral oil.
-- Mother Nature created it, I just assemble it.
View bondogaposis's profile
bondogaposis
4611 posts in 2259 days
#2 posted 11-07-2013 01:35 PM
I use salad bowl finish, no wax. Serving boards are often larger w/ a juice groove around the perimeter.
-- Bondo Gaposis
View Jim Jakosh's profile
Jim Jakosh
20091 posts in 3013 days
#3 posted 11-07-2013 01:37 PM
G’day, Randy!!!!!!!
I think mineral oil alone is sufficient. I use salad bowl finish , personally.The real thing about a cutting board vs a serving board is that the cutting board is best to be made with end grain to lessen the cut depth from the knife, but we all make cutting boards both ways. Also many cutting boards have juice grooves where it is not needed on a serving board.
My 2 cents worth on this beautiful sunny Michigan morning.
Cheers, Jim
View bigblockyeti's profile
bigblockyeti
4994 posts in 1629 days
#4 posted 11-07-2013 01:50 PM
I use mineral oil alone and remind those who have my cutting boards to keep them oiled with the same.
View gwolfe1977's profile
gwolfe1977
228 posts in 1719 days
#5 posted 11-07-2013 02:02 PM
I have used both mineral oil and a butcher block conditioner that has carnuba wax and beeswax in it. I think that the beeswax helps seal the board longer than the mineral oil does.
-- Gary,Nebraska
Blackie_
#6 posted 11-07-2013 02:15 PM
Here is what I am thinking, since I have a large stock pile of Pecan and Cedar Elm I was thinking of using just the boards by themselves with live edges as cutting / serving boards, no cutting into strips and no glue ups.
View Rick  Dennington's profile (online now)
Rick Dennington
5699 posts in 3102 days
#7 posted 11-07-2013 03:18 PM
@ Blackie,
The thing about making boards and trays: You can make them any way you want to….There is no set pattern or special way you have to build them…..It’s a personal project, so just go for the way you want to….Get outside the box, and have fun…....But I would put some protection on the boards, like m.o., or s.b.d….....
Blackie_
#8 posted 11-07-2013 03:51 PM
Thanks Rick, I have both of the finishes,
Thanks everyone, Jim, Monte, Gary, bigblock and bondo.
View jmartel's profile
jmartel
7687 posts in 2058 days
#9 posted 11-07-2013 04:30 PM
Beeswax is not needed, but it adds a bit of additional protection from liquids. Not a ton, and after it wears off, no one who buys the board is going to reapply it, but it does keep the board a bit longer between oilings.
View CalgaryGeoff's profile
CalgaryGeoff
937 posts in 2390 days
#10 posted 11-07-2013 09:09 PM
As others have said bees wax is an option. I use it with mineral oil, I heat them both together in a pot and then apply with a cloth to the board. It gives it a higher gloss finish and soaks in when melted.
-- If you believe you can or can not do a thing, you are correct.
Blackie_
#11 posted 11-07-2013 10:25 PM
Thanks Geoff and jmartel
View Roger's profile
Roger
20904 posts in 2712 days
#12 posted 11-07-2013 10:31 PM
Thnx for clearing a most wondered question Randy.
View kdc68's profile
kdc68
2639 posts in 2185 days
#13 posted 11-08-2013 01:04 AM
I’ve researched the why’s and why not’s. These are the things I found from my research. Opinions vary of course, but I think most concur that it is an option and does provide some extra protection than just mineral oil alone. One would have continue to use the mineral oil/bees wax as part of regular maintenance just as they would with just mineral oil to have the added protection. Store enough of the oil wax combination in a mason jar to maintain the board for several recoats. A 3:2 ratio of oil to wax is good. Heat the mason jar in a double boiler until the wax is liquefied and recoat the board as needed. As it cools it will solidify again. So a reheat is needed each time. Bees wax is cheap and can be found at a health food store. Mineral oil is also cheap and can be found at the pharmacy in the laxative section. Both are far less expensive than the ready made stuff you can buy at the big box store
v
I used the mineral oil/beeswax concoction on this board. And the wax mixture does give it extra gloss
v
http://lumberjocks.com/projects/90231
v
-- Measure "at least" twice and cut once
View Tooch's profile
Tooch
1701 posts in 1784 days
#14 posted 11-08-2013 02:59 AM
mineral oil is all you really need, as long as you recoat often.
-- "Well, the world needs ditch-diggers too..." - Judge Smails
Blackie_
#15 posted 11-08-2013 11:08 AM
Wow here is information, while searching where to buy locally I ran across this bit of important information in regards to beeswax.
Though it is a natural substance, it is possible for beeswax to be tainted with impurities such as pesticide residues. The bees can encounter pesticides while foraging, of course. But pesticides are also sometimes introduced into the hive intentionally by beekeepers to combat pests such as Varroa mites that can decimate a hive. (Though when hives are treated according to guidelines, there should be no pesticides in the hive during honey harvest.)
It’s just something to be aware of – particularly if you plan on using the wax in a way in which it will contact food or be absorbed into the skin (such as making a lotion or balm). If it’s a concern to you, you’ll want to buy organic or even pharmaceutical grade beeswax.
