I am brand new here. I am a senior and I live in Oregon and I am working on a semi finished laminated rifle stock. I would like to buy a hand tool - probably a jack plane - to remove wood from the forend. I haven't bought many hand tools in a long, long time so I would like some help to choose the best jack plane for the money preferably used. I will no doubt use this for other projects. I searched on E-bay and there are lots of planes out there.
Thanks, Hektor
I am assuming that the rifle stock is in the correct dimension….. A block plane would serve you better as it is a better choice to shape the stock to it's desire shape. Jack plane is more for flattening and dimensioning. Not so much on shaping wood. A block plane or apron plane would be more suitable here.
Hello John,
This is a Richard's Micro Fit laminated stock and they typically give you plenty of extra wood so the customers can make it anyway they want. I need to remove wood from the forearm thickness - about 3/4 of an inch.
Is it this stock? http://rifle-stocks.com/laminated_woods.htm
The shape is already established based on the picture….. Just need more info to provide better recommendation. If this is the case a plane would be not suitable. A wood file would be a better choice
The final shaping should be done using a wood file or belt sander.
If this is your first time working with wood files best you take some blank wood and practise. It can screw up your gun stock for not being patient.
If you are still very sure of removing 3/4 of an inch. Then a block plane is suitable. A wood file would take too long. Do you have a picture of the gun stock? I am providing a lot of recommendation without a clear picture….
I have actually done a few of these before, but that was before I was aware of this forum. The stocks come with ample would and lacking for a better word, they sometimes resemble a club. The thumbhole stock I am working on needs to have wood removed - like the last one I made. Their laminated stocks are a little more difficult than the walnut stocks, in my opinion.
I have already epoxied in the aluminum V-block for the bedding, which I had to fit with my router. It will be a nice, tight target stock when I am through. I have used aluminum or steel pillers before. With the V-block, I can use that stock for both of my M 700 target rifles.
I considered a spoke shave, but I kind of think the bigger plane will be more useful for a variety of projects. I have a block plane and a Dremel Multi max roto tool which is pretty handy.
Big planes are really for big going to be flat work. I would use a spoke shave if you are going the hand tool route. You will be surprised how much wood you can remove with one . The school I teach at would poo a brick if a student tried to make a gun stock in wood shop. If you want to keep the shape and your school will let you work on it in their shop, use the power tools (you seem to want to remove wood fast) that is also an option.
I am not a student - I am not certain where that came from. I am retired and this is a semi finished stock. I am merely shaping it on the forend to suit my needs as a prone rifle.
If you're doing a thumbhole stock, a Miller's Falls #1 cigar spoke shave could potentially be very useful. Otherwise a spokeshave, some cabinetmaker's rasps (or Iwasaki rasps are nice), and some French curve card scrapers would be in order. A jack plane is useful anyway and you could use it for rough shaping, but I think a spokeshave is just the ticket here.
The thumb hole shaping / shaving is done already - as I stated, this is a semi finished stock. Again, I am asking about a tool to remove a bit of wood from the forend of the stock. I have used a block plane before, but it takes a while on their laminated wood.
I've built gun stocks and have almost any size plane made, but other than a block plane, I wouldn't see a plane being much help. I do agree with MisterInquisitive, a spokeshave, some cabinetmaker's rasps (or Iwasaki rasps), and some French curve card scrapers would be useful.
I already have the files, rasps, a block plane and I don't require anything to do with making a stock other than to slim down the forend. Like I have already said, I have worked with semi finished wood stocks before.
Here are the following videos I would recommend watching based on block plane and spoke shave.
Spoke shave:
Block plane: This video should help you shape your stock forearm well. I have used a block plane on VERY hard woods. Just have the plane blade sharp. It would be pretty fast.15 mins is more than enough time for a 3/4 thicks at 1 foot
I'm perceiving that Hektor wants to plane a flat at the front of the stock to accept the receiver, without the tedium of using a block plane. Yes, a jack plane would do that, but given that we have no illustrations to better demonstrate exactly what you want to accomplish, it would appear to me that on such a small area, a plain Jane #4 smoother would suffice and would be a better all-around plane.
Once again, the stock came semi finished and I have already fitted the V-block to accept the receiver. I was asking about a way to make it easier to remove wood from the forend. As it has turned out, I just purchased a jack plane from someone on this forum.
I'm going to make a recommendation here. You need a small very sharp spoke shave or what is known as a "float" which is a rasp-like file that has very small FLAT sharp teeth on it. It works like a rasp but leaves a very smooth finish that requires hardly any sanding. Good floats are not cheap but they are wonderful to work with. I use them all the time. Try one and you will never go back to a common rasp for fine work!
I looked at your suggestions and that looks like what I should have all the time. Thanks for the link! I will order some of the files. These are tools you do not find at Home Depot, that's for sure.
Highland Hardware is located here in Atlanta, GA where I live and has been around for a long time (since the 1970s). I have bought from them for years and I know that there are people there that REALLY know what they are doing. I suggest you invest in a telephone call to them and ask to speak to an expert to discuss special tools you might need to do a specific job. Tell them what you are making and I feel certain they can help you select what would be best tool to use and can most likely give you good advice as how to use it. Other than a long time customer, I have no connection with Highland Hardware.
I fitted the bottom rail for the sling hand stop and ventured to the range today to see how this stock fit me in prone. So far it seems that I can shoot comfortably, partly thanks to the thumb hole design. I may have to make and add a cheek piece, but that will come later. I started the wood finish process with some sealer that I bought from Brownells. I think I will end up with Lin-Speed oil finish.
Related Threads
LumberJocks Woodworking Forum
2.5M posts
96K members
Since 2006
