MDF panels
Forum topic by JCantin posted 11-05-2013 09:22 PM 773 views 0 times favorited 1 reply Add to Favorites Watch
View JCantin's profile
JCantin
178 posts in 3321 days
11-05-2013 09:22 PM
Topic tags/keywords: mdf primer
I’m doing a frame and panel wainscoting project in my dining room.
The frames are built already using poplar. Before applying them to the wall I sanded them down to 220 and sprayed them with B-I-N shellac-base primer using my HVLP. Then sanded them to a nice smooth surface.
I’m planning to use a good quality acrylic interior semi-gloss enamel over everything.
Now its time to prep and install the panels. My questions are:
1. MDF vs. Hardboard. Is there any reason to use one or the other? Since the edges will be hidden I don’t have to worry about edge sealing the MDF. Would hardboard give me a better finish though?
2. Priming. Can I use the same B-I-N as primer for the panels?
3. Sanding before priming. If I use MDF is there any point in further sanding before priming?
4. Sanding after priming. I assume a light sand with 320 or 400 would help the final finish?
5 Spray vs brush. I used my HVLP gun to apply the B-I-N on the poplar. Should I go that route for the panels too?
Thanks in advance for any advice.
1 reply so far
View tefinn's profile
tefinn
1222 posts in 2345 days
#1 posted 11-07-2013 03:02 AM
1. I’d go with the MDF. The hardboard doesn’t offer any real advantage and the MDF is probably cheaper.
2. You can use the same primer. It’s actually best to use a shellac sealer like B-I-N on MDF.
3. I don’t sand before priming since it just opens the surface (lots of fuzzies) making it harder to seal.
4. A light sanding will help get a smoother top finish.
5. If you want to spray the panels that’s fine. Helps with a smoother, easier application.
Are you going to spray the finish coat on also?
Make sure you post some pics when you’re done!
-- Tom Finnigan - Measures? We don't need no stinking measures! - Hmm, maybe thats why my project pieces don't fit.
