harbor freight spray can for finish?
Forum topic by JesseTutt posted 11-05-2013 09:05 PM 1425 views 0 times favorited 6 replies Add to Favorites Watch
View JesseTutt's profile
JesseTutt
853 posts in 2019 days
11-05-2013 09:05 PM
Topic tags/keywords: spray finish lacquer
I have several of the harbor freight spray cans where you open the top, pour in a liquid, screw the top back on and then use an air compressor to pressurize the can. (A quick scan of hf’s web site did not bring up a link.) I have had good luck using this to spray WD-40, etc.
I have always wondered if it would work for spraying a finish like lacquer?
404 - Not Found
2544 posts in 2878 days
#1 posted 11-05-2013 10:49 PM
I can’t say whether that particular one will work or not, but I can tell you there are refillable aerosol systems that are designed specifically for applying finishes.
http://shop.preval.com/collections/frontpage/products/preval-val-pak
View Jim Finn's profile
Jim Finn
2622 posts in 2831 days
#2 posted 11-05-2013 10:52 PM
I have read that these systems do a fair to poor job of applying adhesive and a truly lousy job at applying a finish.
View Finisherman's profile
Finisherman
227 posts in 1758 days
#3 posted 11-05-2013 11:34 PM
I’ve never used the harbour freight particular system to apply lacquer, but I have tried the preval one. All I can say is “save your money.” I could have applied a better finish with a plant mister than I got from one of those things. I’m not sure where the problem lies with the preval, but it doesn’t atomize the finish well at all. Even a half pound cut of shellac didn’t spray very well. In short, Jim’s right. Having said that, give the harbour freight unit a try if it doesn’t cost too much money. My one piece of advice would be that you plan on reducing your lacquer to a substantial degree, much more than if you were using a traditional spray system.
404 - Not Found
#4 posted 11-05-2013 11:38 PM
I looked at the Preval one with suspicion, no flow control, no air regulation, no fan settings, no hope of getting a decent finish?
View Earlextech's profile
Earlextech
1160 posts in 2599 days
#5 posted 11-06-2013 01:51 PM
Jesse you’re killing me here!
View CudaDude's profile
CudaDude
179 posts in 2217 days
#6 posted 11-06-2013 02:29 PM
Don’t know about the HF sprayers but several years ago I used a Preval sprayer to spray 2 stage auto paint on a K5 Blazer I repainted. Used it to basecoat-clearcoat the all the hinges, bolts, and the pillars and areas I couldn’t access with the truck assembled. I was very pleased with the results and I promise ya, no one would have known it wasn’t done with a paint gun.
I don’t think you’d get a consistent enough pattern to spray a large area, but for small pieces and hard to access areas they’re very convenient.
-- Gary
