Loose Tenons in 4/4 stock prior to planing down to approx 3/4
« back to Joinery forum
Forum topic by C_PLUS_Woodworker posted 11-05-2013 08:36 PM 1214 views 0 times favorited 7 replies Add to Favorites Watch
View C_PLUS_Woodworker's profile
C_PLUS_Woodworker
601 posts in 2904 days
11-05-2013 08:36 PM
Need just a few comments from loose tenon guys.
Making some decorative (not big, load-bearing) entry-way tables for Christmas.
Only have bits and tenons for 1/4” (and don’t particularly want to buy 3/8 stuff right now)
Working with 6/4 stock for the top (prior to planeing ) and 4/4 stock (prior to planeing) for the rest.
Will my 1/4” bit and the 1/4 inch tenons work OK for the build, considering both the 6/4 and the 4/4 will be planed down.
Here is my concern:
If I use a 3/8 mortise into 4/4 (which get’s real close after planeing to 3/4….....or 6/8) then that leaves only about 3/8’s of wood around the entire mortise. Kinda scares me.
Using Cherry.
Using MortisePal.
Not asking about the table top glue-up, just the joinery.
Thanks, folks.
Bruce.
Edit: Rereading this made me realize that I am really only asking about the 4/4 cherry, cuz no mortise/tenons will even touch the 6/4 top. Now I am not so concerned about the 1/4” bit and tenons.
But, I am certainly still asking…....(if and when I get the 3/8 stuff) .......would 3/8 m/t be too much for 4/4 ?
Sometimes my greatest fear is not being smart enough to even ask the right question.
7 replies so far
View Bluepine38's profile
Bluepine38
3379 posts in 3082 days
#1 posted 11-05-2013 10:32 PM
Just finished helping with a quartersawn white oak kitchen, did the stile mortises for all the doors and
drawers with 1/4” mortise chisel. That left 1/4” on each side of the mortises to match the 1/4” tenon.
A 3/8” tenon would have left 3/16” on each side which is way unbalanced to my way of thinking. The
cabinetmaker I was working for would not even consider it, so I would say my opinion is to stay with
balanced joinery, of course I have occasionally had to admit to be in error, also can not understand
loose tenon, all of mine have to be snug fit.
C_PLUS_Woodworker
#2 posted 11-05-2013 11:13 PM
Feeling MUCH better about using the 1/4”.
Thanks, bud.
Bruce.
117091 posts in 3574 days
#3 posted 11-05-2013 11:41 PM
Bruce my rule of thumb is to make the tenons and matching mortises about one third thie size of the finished material . I’m Pretty much repeeting what Gus said.
View Rick  Dennington's profile (online now)
Rick Dennington
5857 posts in 3191 days
#4 posted 11-05-2013 11:56 PM
Hey my friend…....Don’t worry….be happy….....You’ll be fine making 1/4” tenons….These size tenons and mortises are pretty well the “standard” for this size of material…..If you plane down to 3/4” (S4S) from 4/4 stock, you have a 1/4” material left on each side of the tenon and mortise….Plenty of glue space for the shoulders of the tenon to fit into the mortise…..I have a Delta Mortiser to make the mortises, and I make my tenons one of two ways…...Either with a Delta Tenoning jig, or a set of dado blades on the table saw…...Nearly all my firniture is made with 1/4” m & t….........
C_PLUS_Woodworker
#5 posted 11-06-2013 12:14 AM
Guys, that is very re-assuring
Now, Rick…...........where I have seen that avatar before?
Buddy, Buddy…........ Real Buddy. Blood Brother.
Rick Dennington
#6 posted 11-06-2013 12:54 AM
Bruce:
I thought you might recognize it…....Probably only you and I know what it means…....!!!!!!!
Good luck on the build of your entry-way tables…..Post a couple of pictures when you’re done…..!!!!!!!!!!
C_PLUS_Woodworker
#7 posted 11-06-2013 12:59 AM
Darn Right I remember.
And the motto is SO closely related to:
“Yea though I walk through the valley of shadow and death…..words words words…....................Because I am the ….............words.”
Because we truly were !!
Your Bud
