Mass Prodution of Poker Chip Trays
Forum topic by hdgis1 posted 11-05-2013 05:55 PM 5363 views 1 time favorited 15 replies Add to Favorites Watch
View hdgis1's profile
hdgis1
6 posts in 2141 days
11-05-2013 05:55 PM
I dont normally make this many of anything but got a commision that requires me to make 144 poker chip trays. Drilling out 12 or 14 trays is no big beal but I have no plans to drill 144 (720 holes). Lets hear some ideas on how you guys would approach this.
Chris
15 replies so far
View Sanding2day's profile
Sanding2day
1008 posts in 1723 days
#1 posted 11-05-2013 06:05 PM
Am curious what incredible solution exists but good news as I see it the pieces can be made two at a time and split on the bs, so only 360 holes to drill :)
-- Dan
View chrisstef's profile
chrisstef
17112 posts in 2883 days
#2 posted 11-05-2013 06:06 PM
Some one with a line boring machine might do the trick if they can use a bit that large on the machine.
Stack em up 2 high and you’re down to 180 holes.
View bigblockyeti's profile
bigblockyeti
4909 posts in 1597 days
#3 posted 11-05-2013 06:20 PM
First off I would try to use the longest piece of lumber I could to start with, so that individual trays could be cross cut off the blank. Second I would remove as much wood as possible first on the tablesaw, two cuts at 45 degrees per half cylinder for a total of ten cuts. Third I would look into a bit (probably expensive) that would remove the remaining wood and form the half cylinder the chips sit in. If it were a bit for the router, it would need to be a high horsepower variable speed router, a shaper would be better suited given the requirements of such a bit. Do you anticipate having to make any more in the future? If so the undoubtedly high cost of such a cutter/bit might be easier to justify.
View casual1carpenter's profile
casual1carpenter
354 posts in 2352 days
#4 posted 11-05-2013 06:28 PM
well you beat me to it, lol. was looking up a bit, the Freud 18-130 Round Nose Router Bit 1-1/4 or similar might do you if you remove material first as stated above. bevels or dado to remove bulk of material.
View NiteWalker's profile
NiteWalker
2736 posts in 2453 days
#5 posted 11-05-2013 07:04 PM
A good forstner bit with the dp fence set and those holes will go super quick. I highly recommend colt maxicut bits. They cut incredibly fast and clean.
hdgis1
#6 posted 11-06-2013 12:02 AM
Oops! 360 holes is correct. Math….pffft.
I used the maxicut bits and the do drill well. However, there is an unacceptable amount of tear out that occurs.
I’m really looking for a shaper quality cut that requires minimal sanding.
Chris
116815 posts in 3453 days
#7 posted 11-06-2013 12:18 AM
With that many I would look for someone with a CNC set up.
View PRGDesigns's profile
PRGDesigns
234 posts in 2190 days
#8 posted 11-06-2013 04:04 AM
+1 on the CNC.
-- They call me Mr. Silly
View stevejoly's profile
stevejoly
3 posts in 1934 days
#9 posted 11-08-2013 03:09 AM
What about a router? Make long trays with 5 channels with a cove bit or large round nose bit . Then cross cut the individual trays to length.
View Loren's profile
9775 posts in 3524 days
#10 posted 11-08-2013 03:34 AM
If you did not make the samples, they were perhaps done
on a planer/moulder with custom knives in multiple passes.
Considering sanding and tearout issues, I would entertain
having the coves milled on a cnc machine and sanding
with blocks. Drilling seems goofy, but I’ve never drilled
to achieve a finished profile like that so I can’t say it’s
unfeasible.
View JAAune's profile
JAAune
1772 posts in 2193 days
#11 posted 11-08-2013 03:56 AM
I think a1Jim is on the right track. That sort of work is perfect for CNC. Someone with an industrial machine might charge as much as $250 per hour but they’d have everything done in an hour. You’d probably pay no more than a couple dollars per unit.
I don’t know how wide they are but it would be ideal to mill out long blanks on the CNC then crosscut to length after sanding.
It’s either that or some sort of shaper or molder setup but custom knife grinding fees would probably cost more than CNC milling.
View tefinn's profile
tefinn
1222 posts in 2313 days
#12 posted 11-08-2013 04:50 AM
One of our fellow LJs builds poker chip boxes. Jimboe posted his jig for making the coves for the trays. Maybe you can use a set up like his.
-- Tom Finnigan - Measures? We don't need no stinking measures! - Hmm, maybe thats why my project pieces don't fit.
View InkJetSuperstore's profile
InkJetSuperstore
7 posts in 489 days
#13 posted 04-18-2017 02:10 PM
I’m building a second set of wood chip trays. My first set was built using the wood whisperer method of clamping 2 blanks together and drilling out the holes to create 2 trays. They turned out alright, but there were minor inconsistencies since I couldn’t get my spacing perfect. gclub ไฮโลโมบาย วิธีเล่นไฮโลให้ได้เงิน also wasn’t able to mill some grooves on the underside to make them stackable. I’m now taking another stab at them, but this time I’m using a 40mm cove bit and a CNC router to make them. Today I tried it with 5 racks and the results look promising.
View papadan's profile
papadan
3584 posts in 3245 days
#14 posted 04-18-2017 06:40 PM
I bought clear plastic trays and mounted them on Birdseye maple for my chip cabinet.
View Jim Finn's profile
Jim Finn
2599 posts in 2798 days
#15 posted 04-23-2017 10:12 PM
I have made drawer inserts like this. I use them for small hardware storage. At first I drilled them out and then cut in two but found it much quicker and smoother to just cut the curves on my bandsaw.
