MDF Board
Forum topic by MarkSr posted 11-05-2013 05:12 AM 1708 views 1 time favorited 25 replies Add to Favorites Watch
View MarkSr's profile
MarkSr
215 posts in 1955 days
11-05-2013 05:12 AM
Topic tags/keywords: finishing
Hey guys, what do I have to do with this MDF to accept white spray paint. I put two coats on and it doesn’t even look like I did anything to it. I used a white primer in a spray can. I tried a small scrap piece and it took 2 coats of primer and three coats of semi-gloss white paint to complete it properly, with sanding between 2nd. and 3rd. coat of paint.
The major problem is the ends, like the end grain of plywood, but the top isn’t that much better. Any help would be appreciated. Thanks
-- Mark, ”...NEWBEE: On the road to learning a lot; but; a lot more to learn…” ("My Granddad used to tell me, if you didn't learn something new today, it just wasn't worth getting out of bed")
25 replies so far
View Joe Lyddon's profile
Joe Lyddon
10036 posts in 3957 days
#1 posted 11-05-2013 05:19 AM
Before you paint the ends, put some white glue on the edges… until it doesn’t suck it up… wipe smooth, let dry, then paint, etc.
Something like that…
MarkSr
#2 posted 11-05-2013 05:23 AM
Hey Joe, believe it or not I have a piece drying over night to see if that works, two great minds, huh??
I’ll let you know tomorrow if it works or not. If not, I’ll go out and buy what I am making, the paint will cost 3 times what the whole project is worth. LOL
Thanks for the reply
View Rick_M's profile
Rick_M
11103 posts in 2285 days
#3 posted 11-05-2013 07:12 AM
Spray with shellac then sand with fine sandpaper before painting.
-- http://thewoodknack.blogspot.com/
View JPHW's profile
JPHW
5 posts in 1753 days
#4 posted 11-05-2013 07:12 AM
Hi, what I have used on a few projects is thinned drywall mud. Wipe it with your finger onto any edge or routed profile. Let it dry then sand it off, prime, paint. It works quite well, very easy to sand and fills well. Justin
MarkSr
#5 posted 11-05-2013 07:18 AM
THANKS TO ALL
View oldnovice's profile
oldnovice
6543 posts in 3273 days
#6 posted 11-05-2013 07:50 AM
On the edges I use spakling paste and sand after it dries, comes out smooth as silk.
I have also done this with plywood when I want to paint the edges, again it comes out smooth as glass.
View NiteWalker's profile
NiteWalker
2736 posts in 2482 days
#7 posted 11-05-2013 12:28 PM
What Rick said.
I’ve done the spackle/joint compound/glue size trick and while they all work, with shellac there’s very little waiting.
View poopiekat's profile
poopiekat
4325 posts in 3639 days
#8 posted 11-05-2013 02:16 PM
This is a link to a website that frequently gets posted here in response to MDF finishing problems:
http://forums.shoryuken.com/discussion/67501/how-to-paint-mdf-to-a-mirror-finish-worklog
Joe Lyddon
#9 posted 11-05-2013 07:18 PM
I think I was wrong… Instead of the glue, I think it was as these two guys suggested…
So, if the glue does NOT work, these suggestions WILL work! LOL :)
Let us know if the glue works… OK? LOL :)
JPHW Oldnovice
View tefinn's profile
tefinn
1222 posts in 2342 days
#10 posted 11-05-2013 07:55 PM
You need to prime with a shellac based sealer/primer, or as already suggested just use shellac. Any standard water based primer only preps the surface for the paint to bond better. With MDF you need to seal it. If you don’t have or want to use shellac, you can also use PVA drywall sealer.
-- Tom Finnigan - Measures? We don't need no stinking measures! - Hmm, maybe thats why my project pieces don't fit.
View TaybulSawz's profile
TaybulSawz
156 posts in 1587 days
#11 posted 11-05-2013 08:01 PM
Yep, the thinned drywall mud will work for sure.
-- Still got all my Fingers!!!
View Bluepine38's profile
Bluepine38
3379 posts in 2990 days
#12 posted 11-05-2013 10:45 PM
I use the white Kilz primer on mdf that has to be painted white.
404 - Not Found
2544 posts in 2874 days
#13 posted 11-05-2013 11:46 PM
Normal white emulsion paint for the edges (for walls and ceilings). Paint, sand, paint, sand – and the edges will be filled and smooth ready for primer. Zinsser BIN leaves a smooth opaque primer coat that won’t raise the fibres in the mdf, but clean up is messy (and expensive) and it seems to take longer for waterborne topcoats to dry.
View GOOD LUCK TO ALL's profile
GOOD LUCK TO ALL
418 posts in 1632 days
#14 posted 11-06-2013 01:01 AM
Best I’ve EVER used is Pre-cat primer undercoater I get from Sherwin Williams.
Forget all the other time wasting options, couple of coats, sands baby smooth, powders up nicely, and is ready for paint.
I’ve tried the glue, drywall mud, spackle, by far the pre-cat has worked the best. Plus you can get it tinted for better top coat coverage, win, win
It’s not for everybody, but if your spraying it’s worth a try.
MarkSr
#15 posted 11-06-2013 06:16 AM
Hey Joe & the rest of you guys, as I stated last night I had a piece of MDF with white Elmers glue spread on with my fingers. I let it dry and this afternoon I sanded with 220 grid, by hand, (small sample piece), primed with primer in spray can, sanded lightly w/ 220, and two coats of semi-gloss white from spray can. Looks great. Tomorrow I will try one piece of the project.
Thanks to all.
