Pre-Hung Interior Door Fix
Forum topic by avxflyer posted 11-04-2013 10:46 PM 787 views 0 times favorited 4 replies Add to Favorites Watch
View avxflyer's profile
avxflyer
3 posts in 2054 days
11-04-2013 10:46 PM
I’m looking to reinforce a pre-hung interior door rather than purchase a solid-core replacement. The door was about 7/16” wider than the opening, so I cut the jamb down and then trimmed the hinge side of the door since the other side is bored for the door knob. Cheap being cheap, there’s only about 3/16” of “meat” left after routing the hinge and not enough to secure the hinge screw. Any ideas of adding some reinforcement inside the door where the hinge screws will penetrate? I was thinking about opening up a 1/2” hole behind the hinge and blowing in expanding foam. Not sure a screw will bind to it, but then again, maybe I can pre-install some anchors first. Epoxy?
404 - Not Found
2544 posts in 2846 days
#1 posted 11-04-2013 11:30 PM
Take off the whole edge and glue in a new thicker one. You’d be at nothing with the foam.
View nailbanger2's profile
nailbanger2
1041 posts in 3020 days
#2 posted 11-04-2013 11:34 PM
ditto on renners ^. Except for the winklepickers, since I don’t know what they are, or how they affect trustworthiness.
-- Wish I were Norm's Nephew
Craftsman on the lake
2728 posts in 3314 days
#3 posted 11-04-2013 11:38 PM
What renners wrote is what I was going to advise.
Or.. if it’s one of those white pressed doors it’s probably $29 at home depot. You could cut a little off each side then.
View doordude's profile
doordude
1085 posts in 2860 days
#4 posted 11-23-2013 06:31 AM
avxflyer, in the door business; we call this reblocking. clamp two 1×4’s on either side of door face, use your router with a template guide, and a straight bit. route out all waste don’t get into skin more than a hair. cut a new piece of fir or pine probably 1-1/8” wide and glue back in; reroute for the hinges, and your good to go!
