Can I use a tanning bed to speed up finishing time?
Forum topic by Martin Farley posted 11-03-2013 06:37 PM 1607 views 0 times favorited 15 replies Add to Favorites Watch
View Martin Farley's profile
Martin Farley
17 posts in 2001 days
11-03-2013 06:37 PM
The house we moved into has an old tanning bed that was made in 1989. I’m wondering if I can use it to speed up the drying time on finishing; like polyurethane or gel stains. If so, what would be the best way to set it up?
15 replies so far
View Manitario's profile
Manitario
2630 posts in 2969 days
#1 posted 11-03-2013 06:50 PM
it’s heat, not light that finishes rely on to “cure”; most finishes need some sort of evaporative process to remove the solvent. UV light exposure causes aging/weathering/fading and finish degradation which is what most of us are trying to avoid by finishing our projects!
View bondogaposis's profile
bondogaposis
4899 posts in 2437 days
#2 posted 11-03-2013 08:01 PM
Sounds like a really good way to ruin your finish in a hurry. Most finishes attempt to protect wood from UV rays. I bet a tanning bed would really bypass that and directly damage the wood. On the other hand if you wanted to distress a finish to make it look old there might be an application. It would take some serious experimentation, to get the right look w/ different finishes.
-- Bondo Gaposis
View JoeinGa's profile
JoeinGa
7739 posts in 2093 days
#3 posted 11-03-2013 08:07 PM
Short answer is “NO” it probably would do more harm than good.
The “OTHER” answer is you can work on a really KILLER TAN while your project is drying! :-)
View Bill White's profile
Bill White
5011 posts in 4046 days
#4 posted 11-03-2013 08:54 PM
Beside all the above, you’ll give your project skin cancer.
Bill
-- bill@magraphics.us
View Monte Pittman's profile
Monte Pittman
29673 posts in 2424 days
#5 posted 11-03-2013 09:07 PM
I wouldn’t chance it. Doesn’t sound like even drying. Start another project while it’s drying.
View FaTToaD's profile
FaTToaD
394 posts in 3227 days
#6 posted 11-03-2013 09:24 PM
Some woods, like cherry, develop a natural patina with exposure to sunlight. I wonder if you could use the UV lights from the tanning bed naturally darken cherry, redwood, and possibly other woods PRIOR to finishing them. May be worth throwing a few boards in there to see what happens.
-- David
View kaerlighedsbamsen's profile
kaerlighedsbamsen
1249 posts in 1799 days
#7 posted 11-03-2013 09:28 PM
Perhaps useable if you are using stuff like this: http://www.woodgears.ca/wood_grain/uv_finish.html
-- "Do or Do not. There is no try." - Yoda
View Loco's profile
Loco
210 posts in 1835 days
#8 posted 11-03-2013 09:33 PM
While it’s tanning grab the wifeys curling iron. They work awesome for evaporating paint thinner out of a freshly cleaned brush. I won’t even clue you as to the abilities of a blender or dough mixer….especially gear reduction models from Kitchen Aide.
-- What day is it ? No matter. Ummmm What month is it ? No moron. I paid for a 2 x 6. That means Two inches by six inches. I want the rest of my wood.
Martin Farley
#9 posted 11-03-2013 11:39 PM
Thanks alot for your replies and advice. I was having a bit of a brain fart when I asked this question. Thinking that the tanning bed was putting out as much heat as it was light. The situation I’m in that brought up this question was that the weather is getting colder and I have a ton of projects to urethane and stain before Christmas and I’m trying to figure out a fast way to get my work to dry. I’ve set up my garage pretty decently for a workshop but it can be a trick to keep it warm in the winter time with my kerosene heater and worry about the possibility of a flash flame from the fumes.
View OggieOglethorpe's profile
OggieOglethorpe
1276 posts in 2196 days
#10 posted 11-03-2013 11:42 PM
It would probably darken cherry, though…
404 - Not Found
2544 posts in 3055 days
#11 posted 11-03-2013 11:53 PM
Some industrial lacquers are UV curable but I don’t think it will work for off the shelf products. A small fan heater might suit you better though not pointed directly at your piece.
View BalloonGuy's profile
BalloonGuy
93 posts in 2009 days
#12 posted 11-04-2013 01:19 AM
Martin, I was having trouble getting my finishes to dry in the garage workshop. Lacquer that ought to have been ready for another coat in 1 hour was still tacky after 3. I set up a small fan in one corner and got it to create some circulation (no added heat). Viola! Cure time back down to what the label said it ought to be. A little air movement might be what you need.
-- Tom Peterson, Omaha, NE
View alohafromberkeley's profile
alohafromberkeley
257 posts in 2490 days
#13 posted 11-04-2013 01:26 AM
Don’t know if it’ll work, but I’d be afraid my work would look like George Hamilton!
-- "After a year of doing general farmwork, it was quite clear to me that chickens and I were not compatible"-George Nakashima
woodbutcherbynight
5491 posts in 2495 days
#14 posted 11-04-2013 03:30 AM
NO, and your wife/ girlfriend / significant other might be upset you re-purposed such devices. (laughing)
View bobasaurus's profile
bobasaurus
3525 posts in 3270 days
#15 posted 11-04-2013 03:36 AM
I wonder if you could tape down masking patterns to UV-sensitive wood then use the tanning bed to darken the rest. You could make leaf patterns in padauk or something… might look neat.
-- Allen, Colorado (Instagram @bobasaurus_woodworking)
