best way to plug & seal holes in dust collector ring?
Forum topic by JesseTutt posted 11-02-2013 08:18 PM 1090 views 1 time favorited 7 replies Add to Favorites Watch
View JesseTutt's profile
JesseTutt
853 posts in 1985 days
11-02-2013 08:18 PM
Topic tags/keywords: dust collector modify dust collector seal leak
I am continuing the project of revamping my harbor freight dust collector. I have designed a new mounting system for the dc ring. I need to decide how to plug and seal the various holes that used to have bolts in them. There are three sets of two threaded holes for the old mounting method, and one set of two holes where the plastic handle used to be mounted.
I have considered using silicone and the bolts, using silicone alone, or trying to use the foil tape used by HVAC people.
This area would be under pressure (inside to outside).
What would you advise?
7 replies so far
View johnstoneb's profile
johnstoneb
2692 posts in 2047 days
#1 posted 11-02-2013 09:39 PM
Put the bolts back in the holes.
-- Bruce, Boise, ID
View Grandpa's profile
Grandpa
3259 posts in 2550 days
#2 posted 11-02-2013 10:01 PM
+1 on putting the bolts back. Use carriage head bolts to make it smoother on the inside maybe.
JesseTutt
#3 posted 11-03-2013 01:18 AM
A couple of the bolts did not completely seal, what are the ramifications of putting silicone caulk on the threads prior to reinstalling the bolts?
Grandpa
#4 posted 11-03-2013 01:48 AM
On the threads….no problem now or later. Apply liberally and wipe off the excess after it is tight. I believe Clear Vue recommends DAP AFlex caulk to seal things. Either should be good. Allow to dry before turning on the collector.
JesseTutt
#5 posted 11-03-2013 11:33 PM
Thanks.
I am surprised no one thought that the foil tape HVAC people use to seal ducts was a good idea. Is there a reason?
Grandpa
#6 posted 11-04-2013 03:20 AM
I use it at times but it is not solid like a bolt and nut with caulk sealant….at least to me.
you only got 2 opinions though
View gtbuzz's profile
gtbuzz
427 posts in 2316 days
#7 posted 11-04-2013 12:29 PM
I’ve done something similar with a different DC. You’re on the right track, just bolts and some silicone caulk to seal it up. If you ever need to remove it, admittedly, it’s a pain, but hopefully you won’t need to do that. Since this is in the ring and after the impeller (positive pressure), if you have leaks here, it’ll be pretty obvious. There will be dust escaping around the head of the fastener. If it were forward of the impeller (negative), there would just be reduced performance.
That silver HVAC tape would probably work, but the reason I didn’t go with it is because I had to go over a fastener head. Since it’s not a smooth profile, you’ll get a little wrinkle in the tape, which could be a leak if its big enough.
