Circular saw blade
Forum topic by ashahidan posted 11-02-2013 10:09 AM 993 views 0 times favorited 9 replies Add to Favorites Watch
View ashahidan's profile
ashahidan
64 posts in 2968 days
11-02-2013 10:09 AM
I plan to rip some planks with my 7 1/4 inch Skilsaw . The saw is fitted with a crosscut blade. Is it necessary that I fit the saw with a rip blade ?
ashahidan
-- asm
9 replies so far
View Tedstor's profile
Tedstor
1643 posts in 2502 days
#1 posted 11-02-2013 11:48 AM
WHat kind of crosscut blade? 40 tooth? 60 tooth? WHat kind of wood are you cutting?
Generally speaking, a crosscut blade will do a crappy job ripping wood. Your feed rate will have to be really slow and you’ll likely scorch parts of the wood.
You can buy an appropriate blade for about $10. I’d urge you to go that route.
View richgreer's profile
richgreer
4541 posts in 2944 days
#2 posted 11-02-2013 12:45 PM
You’ll have to go slow and you will not get a very clean cut. I have a combination blade on my table saw. I use it to rip when I only have a little wood to rip. I switch to a true ripping blade when I have a large amount of ripping to do. There is a difference. I go faster and it a better cut with the ripping blade.
View waho6o9's profile
waho6o9
8065 posts in 2446 days
#3 posted 11-02-2013 12:51 PM
Maybe take a couple of light passes, however, purchasing the
correct rip blade would be better.
View EEngineer's profile
EEngineer
1089 posts in 3483 days
#4 posted 11-02-2013 01:57 PM
I use this blade from HD.
With 24 teeth, it does a decent job cross-cutting or ripping. And it cuts like buttah! I am really sold on the Diablo line of blades – good price, great performance and, so far (knock on wood), they have lasted well.
View Whiskers's profile
Whiskers
389 posts in 1896 days
#5 posted 11-02-2013 02:17 PM
Freud Diablo blades are great buys for the money. It’s all I use now. They cut clean every time without biting into your wallet badly and are available nearly everywhere. Amazon carries them if you don’t feel like chasing them down.
View Bill White's profile
Bill White
4816 posts in 3830 days
#6 posted 11-02-2013 02:32 PM
A short answer to your question…...YES.
Buy a ripper.
Bill
-- bill@magraphics.us
View distrbd's profile
distrbd
2252 posts in 2316 days
#7 posted 11-02-2013 03:38 PM
DIABLO
Demo Demon Blade 7-1/4 Inch is the meanest blade I have ever used on a circular saw,it’s 24 teeth rips through wood with ease,I don’t know if you have these blades available in your part of the world but if it is,I highly recommend it.
-- Ken from Ontario, Canada
Tedstor
#8 posted 11-02-2013 06:26 PM
Yep. Diablo 7 1/4 blade. I sometimes use one on my table saw.
ashahidan
#9 posted 11-02-2013 10:34 PM
Tedstor,
The blade I have on the Skilsaw is an 80 tooth type. It makes very smooth crosscuts every time. I do not wish to damage it. So I will get a ripping blade .
Richgear,
Almost all tool shops in my area did not even understand what is a combination blade.
As everyone suggests that I use a proper ripping blade I will get one. I have never use a circular saw for ripping planks before. I am scared of kickbacks.
Thank you everybody
-- asm
