Polyurethane Varnish
Forum topic by Kv0nT posted 11-02-2013 12:45 AM 1239 views 0 times favorited 11 replies Add to Favorites Watch
View Kv0nT's profile
Kv0nT
84 posts in 2089 days
11-02-2013 12:45 AM
Topic tags/keywords: varnish finishing polyurethane finish table old masters
Okay, so I posted earlier that I was having difficulty finishing a table with poly varnish. I used Old Masters because I have had great success with their stains and lacquer. Unfortunately the polyurethane varnish seems to suck. I am using semi-gloss, and even with over 25% Mineral Spirits to thin, I am still having huge bubble issues. No matter how hard I try I can’t work them out, and they don’t pop out on their own. Upping the MS% and using it as a wipe on poly works fine, but I don’t want to do that for a dining table top that gets constant use.
Does anyone have a suggestion for a high quality semi-gloss polyurethane varnish where bubbles are less of an insurmountable problem?
Thank you in advance.
11 replies so far
View gfadvm's profile
gfadvm
14940 posts in 2652 days
#1 posted 11-02-2013 01:17 AM
I spray Spar Urethane undiluted and have never seen the “bubble problem”.
Do you shake the poly can to mix it?
What are you applying the poly with?
I’m trying to figure out where your bubbles are coming from- application technique or from the wood?
Kv0nT
#2 posted 11-02-2013 01:38 AM
lol no I don’t shake. I stir. And I was applying with a staining pad, but I have also tried a foam brush. I don’t have the set up to spray.
View tefinn's profile
tefinn
1222 posts in 2399 days
#3 posted 11-02-2013 01:53 AM
Use a pure bristle brush. Never use a pad or foam with poly. You can also use a polyester brush, but you’ll get better results with the natural bristles.
-- Tom Finnigan - Measures? We don't need no stinking measures! - Hmm, maybe thats why my project pieces don't fit.
gfadvm
#4 posted 11-02-2013 02:15 AM
I agree with Tom. Foam and those pads put bubbles in your finish.
I have wiped on up to 22 coats for a table top. Time consuming but no bubbles!
View pintodeluxe's profile (online now)
pintodeluxe
5617 posts in 2775 days
#5 posted 11-02-2013 02:19 AM
I spray all my tables with pre-catalyzed lacquer. They have held up well to 5 years of daily family dining. That is with two coats, which you can finish in an afternoon. Spraying the finish will solve the bubble problem. It is hard to get a good finish with a brush, but almost effortless with a basic gravity feed HVLP gun. I have sprayed poly too, also with excellent results. I only use poly for exterior use though.
tefinn
#6 posted 11-02-2013 02:34 AM
Pinto, what brand lacquer do you use?
pintodeluxe
#7 posted 11-02-2013 02:41 AM
I have used Magnalac, Valspar, and Sherwin Williams and they all work great. Thin 10% with lacquer thinner for best atomization.
For poly I use Deft brand.
tefinn
#8 posted 11-02-2013 02:55 AM
Thanks Pinto! The Deft spray can lacquer’s getting very hard to find in my area as well as the gallons. I use spray cans on most of my smaller projects, on the larger stuff I use the HVLP. The HVLP is a pain to set up and clean for one small box or such . I’m thinking of getting a detail sprayer or an air brush and using that for the small stuff, but I’m looking for another brand lacquer that’s readily available so I can use it in the HVLP also.
View Picken5's profile
Picken5
250 posts in 2654 days
#9 posted 11-02-2013 02:59 AM
When I’ve used poly, it’s usually been regular ole MinWax brand I’ve picked up at my local big box store. I don’t shake the can, but I do stir it thoroughly being careful not stir too rigorously. I’ve had very good results using foam brushes on flat surfaces such as table tops. And I don’t thin at all. I generally apply by brushing slowly with a single stroke — only stopping to reload the foam brush and continuing the stroke. I’ve also found that brushing over someplace I’ve missed can be a problem if the poly has started to set-up at all. So it’s important to watch the coverage carefully. I’ll usually see some bubbles immediately after applying the poly this way, but the go away well before it dries. And the first coat always needs to a light sanding after it’s dry. I apply the second coat the same way as the first. For me. foam brushes are a bit tricky on vertical surfaces. It’s hard to avoid loading the foam brush too heavily and I sometimes get runs that need fixing. But on horizontal surfaces, foam works great for me.
-- Howard - "Time spent making sawdust is not deducted from one's lifetime." - old Scottish proverb
Kv0nT
#10 posted 11-02-2013 11:50 AM
Thanks for all the advice. I am going to try doing a sealer coat of 50/50 poly/thinner wiped down. Then I’ll try the narural bristle brush for another 3 coats. I can always wipe it down with ms if the bubbles in this brand still give me lip.
View Lee Barker's profile
Lee Barker
2170 posts in 2813 days
#11 posted 11-02-2013 02:52 PM
I think the brush is the main culprit here. I highly recommend investing in a good varnish brush, learning to clean it, and delighting in the quality work it permits you to perform.
Go to a paint store that sells to professionals—not a paint department—and check out what they have. You will get what you pay for. If the price tag seems too large, ponder that you’re buying a tool that can last as long as you do.
Kindly,
