Ridgid planer blade question--Update
Forum topic by Sandra posted 11-02-2013 12:17 AM 1826 views 0 times favorited 29 replies Add to Favorites Watch
View Sandra's profile
Sandra
7207 posts in 2223 days
11-02-2013 12:17 AM
Well, it appears that the blades of my 13” planer either need to be replaced or at the very least flipped. There’s a good nick in one of them which would account for the gauging the last time I ran a board through.
Being the instruction reader that I am, I set about using the supplied hex wrench to loosen the screws that hold the blades in place. “Loosen, but do not remove….” No problem until the third screw. It wouldn’t budge, so I put a bit of muscle behind it and it started to strip. I gave it a shot of PB blaster to loosen it up and still no dice.
So….. I have a screw that won’t budge and is now essentially stripped on the cutter head.
Any suggestions?? (Other than buying a DeWalt)
It’s registered with Ridgid, so if need be I’ll call them.
Thanks,
Sandra *UPDATE
The screw extractor set I bought for 14$ at Canadian Tire worked fabulously on the bolt, and I thought the battle was over…. However when I got to the third blade, it had TWO seized bolts. I tried using the extractor on those and the heads of the bolts broke off completely, leaving the shafts in the hole.
So I’ve contacted Ridgid to find the nearest service centre and ask how to go about getting the planer serviced.
I like the Ridgid products I have, and the warranty is appealing. It looks like I’ll be putting it to the test.
Stay tuned….
-- No, I don't want to buy the pink hammer.
29 replies so far
View Joe Weaver's profile
Joe Weaver
518 posts in 3834 days
#1 posted 11-02-2013 12:27 AM
I had that problem, thou the screw was not totally rounded. I have some old auto wrench’s that fit a lot better. was able to change the blade
-- Joe, Ga
Sandra
#2 posted 11-02-2013 12:28 AM
Thanks Joe, I’ll try a different wrench.
View RogerInColorado's profile
RogerInColorado
321 posts in 2102 days
#3 posted 11-02-2013 12:33 AM
Calling Ridgid is an excellent first step. If they don’t offer a solution, go get “the Grabber” screw extractor set. Others may offer options more attractive to you, but any attempts need to include some version of a penetrating substance on the screw and giving it lots of time to soak in. Might even include applying heat to the screw via a soldering iron for example.
Sandra
#4 posted 11-02-2013 12:36 AM
Thanks Roger. I own several Ridgid tools and have never had to call. This may be an interesting test.
Sandra
#5 posted 11-02-2013 12:59 AM
Tried another wrench, no dice. Will leave it overnight to see if the PB blaster helps.
View Monte Pittman's profile
Monte Pittman
29878 posts in 2486 days
#6 posted 11-02-2013 01:02 AM
Historically they send cheap wrenches with the units. Trying a good one could help.
Also, that’s when I call it bad names and threaten it with physical violence. Makes me feel better anyway.
Monte Pittman
#7 posted 11-02-2013 01:05 AM
If you have a dremel tool, you can take the cutter and cut a straight slot in the top of the screw that you can use a flat blade screwdriver to loosen.
Sandra
#8 posted 11-02-2013 01:11 AM
Ahhhhhh Monte, I do have a Dremel! Great idea. (The cursing didn’t work, I tried it….)
13630 posts in 3489 days
#9 posted 11-02-2013 01:13 AM
tap it with a hammer too
after the PB
it can help shock the rust or stress tightening on them
i have gotten a smaller wrench and filed the edges
to fit the best ‘face’ of the head too
or a different socket (metric or sae)
and tap it gently down on them
then use the appropriate ratchet for it
then replace with some good ones
not the same cheap ones
Sandra
#10 posted 11-02-2013 01:18 AM
Thanks David,
I made the mistake of thinking that the one they sent with the planer would be the ‘right’ one to use. Evidently not. Live and learn.
View gfadvm's profile
gfadvm
14940 posts in 2838 days
#11 posted 11-02-2013 01:29 AM
Sandra, I had the same problem with the same planer. Here’s the cure: throw the wrench away that came with it. Then get the correctly sized METRIC driver. Put the driver in the top of the screw and SMACK it with a hammer (you won’t hurt it). Then it should back out. The wrench it came with is soft and mine seemed just sl. undersized.
OK, I went out to the shop and checked mine. You need a 4mm hex driver.
Send me a pm if you don’t get em out this way as there is a plan B
Sandra
#12 posted 11-02-2013 01:35 AM
Thanks Andy. Don’t know that I have a 4mm, but it’s a good excuse to go to HD. First thing in the am, I will be tackling this.
View tefinn's profile
tefinn
1222 posts in 2585 days
#13 posted 11-02-2013 01:39 AM
Sandra – This is not an uncommon problem when changing planer knives, especially for the first time. David’s got it right on. Rapping each screw with a hammer helps release some of the tension on the screws. Just don’t hit them too hard or it might damage the top of the screw. I got a good set of T-handle wrenches to help with getting a good bite and leverage on them when I take mine out.
As far as getting out the one that’s stripped, try what’s already been suggested. If that doesn’t work you may have to drill it out. A lot of times you’ll only need to drill off the head and the threaded end will twist right out.
-- Tom Finnigan - Measures? We don't need no stinking measures! - Hmm, maybe thats why my project pieces don't fit.
View DocSavage45's profile
DocSavage45
8702 posts in 2990 days
#14 posted 11-02-2013 02:12 AM
I’ve used a propane torch to heat and then let cool, usually before anning muscle but the suggestions here are spot on.
-- Cau Haus Designs, Thomas J. Tieffenbacher
View Beaver_Lumber's profile
Beaver_Lumber
6 posts in 2446 days
#15 posted 11-02-2013 02:23 AM
Got the same problem with my Ridgid R4330 planer when I flipped the blade for the first time. Out of the 21 screws holding the knives in place, I had to “persuade” 3 of these in such manner that they were unusable after “persuassion”. I used a screw extractor to get those out. I went to the nearest Ridgid service center and bought like 10 of these just in case for the next time. But before putting the scres back in place, I went to an auto part store and bought some anti-seize. I applied a liberal coat of this on each screw and then put them back in. After some use, I did the test to see if the screws would come out easier and they did. The problem behind this is that the cutting head is made of aluminium while the screws are made of steel. They kind of fuse together with the heat, the vibrations and repeated impacts they absorb over time. The problem is quite well documented on the web and many Ridgid and other planers brands owners, including the DeWalt DW735, have been facing this problem…
-- Patrick - A beaver is like a woodworker because it needs to have wood between its paws
showing 1 through 15 of 29 replies
