| Forum topic by anqi | posted 1627 days ago | 1016 views | 0 times favorited | 12 replies | ![]() |
1627 days ago |
Topic tags/keywords: question Any substitute cutters for original Stanley’s? |
12 replies so far
#1 posted 1627 days ago |
If you are looking to replace them with a premium iron I would recommend Hock Tools I replace the blades on my #5 and #8 Stanleys recently and the blades improved their performance remarkably. These blades are not cheap but they are well worth the money. -- Challenges are what make life interesting; overcoming them is what makes life meaningful- Joshua Marine |
#2 posted 1627 days ago |
Hock+ -- Jimmy, Oklahoma "It's a dog-eat-dog world, and I'm wearing milkbone underwear!" |
#3 posted 1627 days ago |
Hock -- Thos. Angle, Jordan Valley, Oregon |
#4 posted 1627 days ago |
Thank you all! |
#5 posted 1627 days ago |
I replaced the blade on my #8 with a Hock blade…. Never been happier! :) -- "Everything that is great and inspiring is created by the individual who labors in freedom" -- Albert Einstein |
#6 posted 1625 days ago |
+1 Hock I would recommend the chip breaker as well. Craftsman Studio has consistently had the lowest price IME and has free shipping special. No affiliation, just a happy repeat customer. -- Doug, woodworking in Alabama |
#7 posted 1625 days ago |
Sounds like a TB ward. I’ll go with Hock, too(y). -- Tim-- http://www.tmuli.com |
#8 posted 1625 days ago |
Since no one else said it, I will. Lie-Nielsen also sells replacement blades for Stanley’s. |
#9 posted 1624 days ago |
Woodcraft and Klingspor’s also sell Stanley blades (now made in the UK). If you go to the Hock blades you will need to back up the frog, as the Hock irons are thicker. A hock chip breaker by itself will stiffen up a thin iron (Dunlap or Marshall Wells) if you have chatter, or want to turn an old #5 into a scrub plane, etc. I have used both new Stanley’s and Hocks, and prefer to spend the extra for the Hocks as they hold an edge much longer in hard wood. But, if you want to radically radius an iron for scrub work, and don’t want to use an expensive iron, the $3 two-inch Buck Brothers irons at home depot are cheap but will hold up well for scrub work and fit both Stanley and Dunlap planes up to #5. It will take a bit of effort to flatten the back, tho, as they have heavy mill marks. Go -- Go http://ncwoodworker.net/pp/showgallery.php?cat=500&ppuser=730 |
#10 posted 1624 days ago |
Hi, Gofor, What do you mean about back up the frog? Thanks. anqi |
#11 posted 1624 days ago |
Hi anqi, I think what he means is that you will need to adjust te frog back in it’s slot so te thicker iron will not run into the front of the mouth. -- Scott - Chico California http://chicowoodnut.home.comcast.net |
#12 posted 1622 days ago |
Scott is correct. If you currently are using a Stanley blade, and you have the mouth set close for fine shavings, the thicker hock blade may run into the front edge of the mouth, dulling it before you even use it. Be careful the first time you insert the Hock blade to make sure this doesn’t happen. If it appears it will hit, loosen the frog screws and back it up some. Realize you can set the frog behind the rear edge of the mouth opening, because the bevel of the iron will still allow the cutting edge to clear. Go -- Go http://ncwoodworker.net/pp/showgallery.php?cat=500&ppuser=730 |
| Forum | Topics |
Woodworking Skill Share
8781 |
Woodturning
219 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
77 |
Finishing
1521 |
3541 |
15746 |
Hand Tools
2027 |
Jigs & Fixtures
493 |
Wood & Lumber
2832 |
808 |
Focus on the Workspace
899 |
766 |
Woodworking Trade & Swap
2736 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6148 |
