A nice cheap vacuum dust collector remote
Forum topic by Kaleb the Swede posted 11-01-2013 09:40 PM 1929 views 0 times favorited 14 replies Add to Favorites Watch
View Kaleb the Swede's profile
Kaleb the Swede
1879 posts in 2204 days
11-01-2013 09:40 PM
Topic tags/keywords: tip
I found this thing at my local lowes in the seasonal section. It is used to turn on outdoor lights. Three different outlets fit in it. I put one in my shop vac and one in my 1 hp dust collector. Now I can turn them on with a touch of a button from anywhere in the garage. I realize this wont work for bigger dust collectors but if you have a small one like me it works just fine. And for those of you with a shop vac it works great. Three different selectors for 19.99. Last I checked to get a remote control start for a dust collector or shop vac at woodcraft it cost close to 70 bucks. This one runs three things for 20. Thought some of you would like to know.
-- Just trying to build something beautiful
14 replies so far
View MarkwithaK's profile
MarkwithaK
370 posts in 3412 days
#1 posted 11-01-2013 10:27 PM
Very interesting. What’s the max amp rating on something like that?
-- If at first you don't succeed then maybe skydiving isn't for you.
Kaleb the Swede
#2 posted 11-01-2013 10:31 PM
15 amps. Guess I should’ve said that. It’s not for something big, but it works for the smaller stuff
View Richard H's profile
Richard H
489 posts in 1915 days
#3 posted 11-01-2013 10:35 PM
I used something like this for a while and it works great for smaller systems. One thing though is always remember to turn off or unplug the dust collector and shop vac when you are done. I had mine turn on in the middle of the night when I forgot to do that once. Not sure if it was just random RF noise or a issue with the unit but I guess it’s a good thing it happened when I was home.
117416 posts in 3811 days
#4 posted 11-01-2013 10:43 PM
I use the same unit works great .
View kdc68's profile
kdc68
2692 posts in 2511 days
#5 posted 11-01-2013 11:39 PM
Thanks for the info !
-- Measure "at least" twice and cut once
MarkwithaK
#6 posted 11-02-2013 02:10 AM
Thanks Swede
View NiteWalker's profile
NiteWalker
2738 posts in 2811 days
#7 posted 11-02-2013 04:19 AM
Do you know the sku?
I’m having a rough time finding it on lowe’s website.
View GFYS's profile
GFYS
711 posts in 3705 days
#8 posted 11-02-2013 04:39 AM
I use a similar one…the remote is on a key fob though. I have three separate receptacles so I can plug them into wall receptacles on different branch circuits
Kaleb the Swede
#9 posted 11-02-2013 01:01 PM
I looked on the website also nitewalker but didn’t see it. It was right in the seasonal section at lowes however.
http://t.homedepot.com/p/Heath-Zenith-Outdoor-Remote-Kit-SL-6139-D/100654967
This is one at Home Depot that may work.
View Nicky's profile
Nicky
695 posts in 4326 days
#10 posted 11-02-2013 01:51 PM
I’m off to lowes this morning to pickup some plywood. I’ve always wanted one of these remotes.
Thanks for the tip.
-- Nicky
View MrRon's profile
MrRon
5261 posts in 3478 days
#11 posted 11-02-2013 06:26 PM
You could get an inexpensive relay and wire it into the remote. The contacts on the relay would be sized to operate a larger motor, even 220 V. Look in Grainger for relays.
View crank49's profile
crank49
4032 posts in 3205 days
#12 posted 11-02-2013 09:00 PM
Wait and go back the week after Christmas and they sell for $10.
I bought two last year.
View pmayer's profile
pmayer
1032 posts in 3300 days
#13 posted 11-02-2013 09:08 PM
I use one like this on my 5 HP cyclone, wired as MrRon suggests. I have remotes positioned near each of my major tools.
The suggestion to unplug it is a good one. In the last couple years, I have had mine turn on spontaneously a hand full of times. I have tried all three of the frequencies that it supports and it still turns on from time to time. The culprit is garage door openers. Its strange that a garage door opener would trigger it occasionally; I would think it would either do it, or not do it. My garage door opener has triggered it a couple times, and other times it could have been something else but I am guessing that it was my one of my neighbors’ garage door opener.
View taoist's profile
taoist
124 posts in 2725 days
#14 posted 11-02-2013 09:13 PM
I bought a HD model a few years ago that came with 3 different receivers, only one key pad, for about 15 bucks. The only occasional problem I have with it is that it’s plugged into a ground fault receptacle and it will trip the built in breaker. A walk across the shop remedies the situation.
