Spring-loaded thing on a chuck key
Forum topic by Loren posted 11-01-2013 07:33 PM 1840 views 0 times favorited 29 replies Add to Favorites Watch
View Loren's profile
10477 posts in 3889 days
11-01-2013 07:33 PM
What is the purpose of this thing? Is it just there to force
you to push real hard?
29 replies so far
View SCOTSMAN's profile
SCOTSMAN
5849 posts in 3826 days
#1 posted 11-01-2013 07:35 PM
No it’s designed so you don’t inadvertently leave the key in the chuck when you spin it up .A dangerous thing to do. Alistair
View teejk's profile
teejk
1215 posts in 2925 days
#2 posted 11-01-2013 07:35 PM
It’s to prevent you from leaving the key in the chuck when you hit the “on” button.
View FaTToaD's profile
FaTToaD
394 posts in 3382 days
#3 posted 11-01-2013 07:38 PM
Interesting, I’ve always wondered that myself! You learn something new every day…
-- David
#4 posted 11-01-2013 07:43 PM
Ok. Thanks. I guess I won’t remove it then.
teejk
#5 posted 11-01-2013 07:43 PM
Forgot to add…it is a PITA but so is starting a lawn mower in the past 20 years and newer gas cans are about the same. But you’ll get used to it.
Darwin was a pretty smart guy but we don’t let his theory work. In the meantime we all pay a lot more for everything.
View Grandpa's profile
Grandpa
3261 posts in 2916 days
#6 posted 11-01-2013 07:45 PM
They are right on with “it is there so it will kick out before you power up”. Often times the chuck wrench is attached to a chain so it won’t get lost. This makes them especially dangerous if they are left in the chuck.
View crank49's profile
crank49
4032 posts in 3212 days
#7 posted 11-01-2013 08:48 PM
Yea, just to keep you from leaving the key in the chuck, but I removed mine and low and behold, the sky did not fall and I have not hung myself on the cord that ties the key to the press column either.
Two years ago gas cans reached a new high for inconvenience. You had to push one leaver one way while you pulled another the other way to get the can to release any gas. Of course it took two hands to open the frigging valve while you had to use your third hand to actually turn the can up to pour gas. Then if you blinked an eye the damn thing snapped shut again.
I discovered that if you broke off the correct little thingy the can would not dispense any gas till you pulled the trigger. Then would shut off when you released the trigger. I think my modification made the can way more practical and useful and just as safe. Of course the next year they changed the design again. Crap.
View PurpLev's profile
PurpLev
8548 posts in 3889 days
#8 posted 11-01-2013 08:50 PM
as mentioned – it’s a safety mechanism to make sure the key stays out of the chuck when not in use – a great little feature!
teejk
#9 posted 11-01-2013 08:54 PM
Grandpa (and anybody else)...The chain is long gone. I nailed an electrical staple at an angle that holds the key very nicely.
View darthford's profile
darthford
612 posts in 2165 days
#10 posted 11-01-2013 09:05 PM
Drill press nanny, I dislike them.
View RussellAP's profile
RussellAP
3104 posts in 2527 days
#11 posted 11-01-2013 09:49 PM
My chuck is on a stove pipe wire connected to the drill press. forgetting to take it out is a serious thing.
darthford
#12 posted 11-01-2013 11:13 PM
Albrecht keyless chuck, I’m just saying.
View lieutenantdan's profile
lieutenantdan
176 posts in 2547 days
#13 posted 11-02-2013 12:31 AM
darthford,
Is that a Ridgid drill press?
-- "Of all the things I have lost in life, I miss my mind the most."
View Picklehead's profile
Picklehead
1053 posts in 2170 days
#14 posted 11-02-2013 01:08 AM
Here’s a quick mod I did to my drill press. Rare earth magnet in a shallow forstner bit hole, opposite a drilled hole to hold drill chuck key. Magnet holds thingamajig to drill press and holds key in place.
-- Quote from ebay tool listing: " Has nicks and dings wear and tear dust and dirt rust and pitting but in good working condition"
View gfadvm's profile
gfadvm
14940 posts in 2931 days
#15 posted 11-02-2013 01:30 AM
Keyless chuck is my friend!
showing 1 through 15 of 29 replies
