I am having tons of trouble re-finishing a table top.
Forum topic by Kv0nT posted 11-01-2013 01:05 AM 919 views 0 times favorited 3 replies Add to Favorites Watch
View Kv0nT's profile
Kv0nT
84 posts in 2122 days
11-01-2013 01:05 AM
Topic tags/keywords: finishing varnish urgent going insane dust table table top
I have a great QSWO arts and craft table that I am refinishing. It is not going well… First I wanted to use lacquer, but I don’t have a spray room, and the lacquer drys too fast to apply by hand.
So I used Old Master’s Poly-U varnish, and for some reason when I apply it, it leaves these gross bumps everywhere. I can sand them down easily, but after a few coats the finish now looks horrible. I do not believe that dust is the culprit. I tack of the table every time, and the room I am using is relatively dust free.
Is there a better product out there or am I doing something technically wrong? I have been using a Home Depot brand staining pad to apply the varnish… Is this the problem?
3 replies so far
View Clint Searl's profile
Clint Searl
1533 posts in 2356 days
#1 posted 11-01-2013 01:26 AM
Strip it. Wash it down with naphtha. Let it dry a couple days. Finish with waterborne poly floor finish (I like Bona Mega).
Nothing else!
View redSLED's profile
redSLED
790 posts in 1887 days
#2 posted 11-01-2013 01:29 AM
Some possibilities . . .
- If you didn’t strip and sand down to the bare wood, you might have a shellac and/or lacquer and/or wax and/or silicone polish finish (i.e., “Pledge”) that you didn’t remove/sand/prepare properly before varnishing
- Your varnish is bad quality/too old/wasn’t stirred well/was previously stored in frozen temperatures
Your staining pad is likely NOT the problem with your results.
Kv0nT
#3 posted 11-01-2013 01:34 AM
I think the varnish quality has to be bad, or it was stored improperly by the seller, because it’s brand new and I stir it before I start each half of the table.
Fully removing the previous finish is definitely not the issue.
